Parentnoia Posted November 22, 2012 Report Posted November 22, 2012 My Check Engine light has been on for a while and with it being Thanksgiving, I convince my uncle to pull out his OBDII scanner and check it for me. His scanner came to the conclusion that I'm running rich (which explains a lot now). He thinks it might be the fuel pressure regulator but when we went to check it he realized that it's internal. Is there any other things to check before we drop money on the repair? The engine is a 5.7l V8 350ci Vortec 5700. It's the one with the spider injectors. 1999 GMC Suburban SLTNo system planned just yet. Look at "hate" spelled backwards. It spells "e-tah." For example, if you hate me you can e-tah dick.
fox_racin4 Posted November 22, 2012 Report Posted November 22, 2012 Bad O2, Plugged air filter 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Parentnoia Posted November 22, 2012 Author Report Posted November 22, 2012 Well it's been hard to start since the day I got it. The air filter has been changed twice since then and he says that the o2 sensors on both banks wouldnt go bad at the same time. 1999 GMC Suburban SLTNo system planned just yet. Look at "hate" spelled backwards. It spells "e-tah." For example, if you hate me you can e-tah dick.
fox_racin4 Posted November 22, 2012 Report Posted November 22, 2012 Whatbuear is it? My 98 has 3 o2s One per header the one afyer the cat 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Parentnoia Posted November 23, 2012 Author Report Posted November 23, 2012 Whatbuear is it? My 98 has 3 o2s One per header the one afyer the cat 99 Suburban 1999 GMC Suburban SLTNo system planned just yet. Look at "hate" spelled backwards. It spells "e-tah." For example, if you hate me you can e-tah dick.
SLYentist Posted December 20, 2012 Report Posted December 20, 2012 It could possibly be a coolant temperature sender/sensor. Check on some chevy forums and see if those are prone to failure for your particular car. If the sensor misreads coolant as being too cool, it will dump fuel into the combustion process to create more heat to get the motor to prime operating temp. Also, how old is your thermostat? If it's old, it's possible, but unlikely, that it broke and is stuck closed (usually they're stuck open when broken). You've got a mess of coolant under the hood, and I'm willing to bet that either you overheated and the radiator cap blew off under pressure, or you just have a cap that didn't seal in the first place. Cables and wires almost never fail; the terminations do.
deathcards Posted December 21, 2012 Report Posted December 21, 2012 maf sensor, poor spark, 02 sensor, air filter ( depending on conditions may need to be replaced more often) skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
Parentnoia Posted January 19, 2013 Author Report Posted January 19, 2013 Alright, since the problem is still persisting, I figured I'd revive this thread but take the time to state the symptoms chronologically. Started with the day we bought the truck in May 2012. It's been hard to start. I have to let it crank for 10-15 seconds before it starts up, but some occasions (mostly cold mornings) it'll start right up. The previous owner said the problem popped up in the last few days after an oil change. After a few weeks of drive it around, you could no longer feel the A/C condenser kick on when the button was pressed on the dash.Around that same time, we started to notice the smell of gas in the truck when the windows were down, but we just attributed that having just filled up. Another few days later, we noticed that the smell is stronger under the hood and at the exhaust. When we noticed it under the hood, we were getting the oil changed and one of the other mechanics that was working with my uncle said it smelt like a EGR leak. When my uncle got home that night, I asked him about it and he said yeah, it could be, but not to worry about it. And he also said that the hard start issue could be the fuel pump (since you can hear a distinct whining from the rear of the truck which my uncle says is the fuel pump) or it could be the fuel filter. So fast forward the October 7, 2012 when I decide to change my oil and while I'm under there, I decide to replace the fuel filter, but that didnt fix the problem. Fast forward to Thanksgiving 2012 when I talk my uncle into hooking his scan tool up to the truck. That results in the codes:P0172 Rich Bank 1 P0175 Rich Bank 2 P0300 Misfire [*]A week or so later, we run a pressure test that results in an idle pressure of about 60 PSI which spikes to 70 then down to 40 PSI (as one motion) immediately after turning off the engine then down to 20 in a matter of a couple seconds. Now here I sit, with no improvement, wondering if there's something I still have not changed, like spark plugs, distributor, etc. 1999 GMC Suburban SLTNo system planned just yet. Look at "hate" spelled backwards. It spells "e-tah." For example, if you hate me you can e-tah dick.
R James Trapp Posted February 17, 2013 Report Posted February 17, 2013 The coolant temp sensor is a legit concern. In the mornings when it's cold and starts right up. But the o2sensors also tell the computer whether its lean or rich. If the sensors are bad, it could be telling the ECM it's lean and pulse more fuel. Man there's a lot of things it could be, sucks I can't put my hands on it to check those things. I'd start with the 02 sensors and change them out. eBay is the cheapest route if you can get the part numbers and shop by those. Then, if your uncles scanner can data stream and show you coolant temp, get the engine hot(180 or above) and see if you can barrow or rent a infrared temp gun to get the actual temp off the the engine below the thermostat. Front of a head or block and compare what the scanner says the sender is reading. If the engine won't get to 180 then the thermostat is tits. There's a starting point I guess. Wish I could have the truck in front of me to help you.
