knowledge Posted November 23, 2012 Report Posted November 23, 2012 no i took off the back plate of the amp and Wait you fiberglassed it right into the amp? no i took off the back plate and cut the hole into the back of the back plate and when im done i can just screw the back plate back on so yes i guess i did glass it right onto the amp you said no than you said yes lol. REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
Rockford96 Posted November 23, 2012 Author Report Posted November 23, 2012 Never seen a fan with a remote wire. That fan appears to have a fluid bearing which will seize up eventually if not ran straight up and down as intended. EDIT: The yellow wire on the fan (and most other 3-wire PC fans) is for PWM control, how it will function as a remote turn-on I cannot say. i was not aware of the bearing but thank you for the advice ill be sure to mount the amp so the fan is upright when i do thanks again My setup, Digital Designs M80 3 Re audio 10's ported tuned to 36 hz Kenwood x-696 SHCA 0 gauge Polk audio coax running off hu
8ight Posted November 23, 2012 Report Posted November 23, 2012 Never seen a fan with a remote wire. That fan appears to have a fluid bearing which will seize up eventually if not ran straight up and down as intended. EDIT: The yellow wire on the fan (and most other 3-wire PC fans) is for PWM control, how it will function as a remote turn-on I cannot say. i was not aware of the bearing but thank you for the advice ill be sure to mount the amp so the fan is upright when i do thanks again No problem! I'm gonna hate
