Focus Acoustics Volvo S70 from Finland
New vid including some numbers. Subs are still kinda stiff, so.. :help:
Volvo S70 - 150.8dB @ 46hz from the trunk of the sedan with 3.5kW
  • 1 month later...
Noup. Just been cruising around and enjoying. :lol: Well there's new port coming soon (larger port with higher tune, trying to break that magical 150dB).
Yiissssss! You should get another port tuned to like 34! Those subs remind me of AQ/DD so I'm assuming you lose upper end if you tune low, but if those subs do well lower then make a 28hz port!!!
E34 540iT/6
He said he's tuning higher, and if it shares the same characteristics of AQ/DD, then tuning lower is a bad idea, especially when the car peaks high
Hope you break that 50 R-to :)
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Yea I know I said that.. ha.. I just said to make ANOTHER port tuned low to swap out for fun sometimes..
E34 540iT/6
He already can do that, when he uses just one 6' aero port instead of 2, he's tuned to 27 hz lol
2003 Kia Sorento
Team Subsonic Lows
Now it's tuned @ 36hz. Peaks 148.8dB @ 48hz (with music). Soooo... If I increase the port area and tune it up to 40-42hz, it also will "breathe" better. ;o I think the enclosure volume isn't enough for three twelves, so only thing I can do properly is playing highs. ^___^ But that's fine, since our new racesong got notes from 38hz up to 59hz.
