Running two sets of components
Nate197
How do most people power component sets... 2 channel amps, 4 channel amps, do they use all four channels up front front and rear channels or does that fuck up the sound. I am going to be running two component sets and was going to use one amp for my mids (4 6.5s) and one for my highs. I have two sets of the Rockford Fosgate T2652-s (http://www.sonicelectronix.com/item_22595_Rockford-Fosgate-T2652-S.html) My question is if I run two four channel amps (I was thinking about running two T400-4 at 4 ohms each http://www.sonicelectronix.com/item_9102_Rockford-Fosgate-Power-T400-4-Black-Box.html) does it matter if I use the rear channels up front. I was going to have 2 6.5s and two tweeters on each door. I have never used component sets and not sure if this way is the best way to hook them up. Thanks
Do you plan on using the crossovers (passive)
or run active?
If you run passive you will only need one 4 channel. It will give you left and right on rear and front it'll give you the option to use the faders
If you run active tweets on channel 1--2 and mids on channel 2-3
Ok thanks!
  • Who's Online   0 Members, 0 Anonymous, 1590 Guests (See full list)
