lownloud87 Posted November 28, 2012 Report Posted November 28, 2012 ok i just bought a rockford fosgate prime 1200-1d online. and the seller says it powers on but no sound and smell burned. dont have the amp yet to look at the inside. any ideas on what the problem could be would be greatly appreciated. thanks Wicked 4 play car club 2002 Chevy 2 door blazer Real soon setup head unit: PTID-8920B subs: 4 12's or 2 15's hevent made up my mind on brand,ported at 33hz amps: for sure two RF 300.4' for mids and highs, 3sixty.2. stuck on wat sub amp ill be using power supply: big 3 1/0, 2 runs of 1/0 power wire and 2 runs of 1/0 ground wire bacc to the second battery, 8awg, 4awg and depending on the sub amp 4 to 1/0 power and grounds for it. speaker wire: 12awg speaker wire and 8awg for subs speakers: 4x6's dash, 6 1/2 components doors, 5 1/4 components kicks, and 6x9's back. all Infinity Reference misc.: 8000k hid low beams/projector headlights, 3/3 lowering kit, D3400 xspower batt up front and rear, ad244 145 amp alternator
ric006 Posted November 28, 2012 Report Posted November 28, 2012 possible the output transistors, and the you could always look at this page http://www.bcae1.com/repairtutorialcdinfo.htm
White Lightning Posted November 28, 2012 Report Posted November 28, 2012 Someone let the smoke out ... I'd start looking into amplifier repair shops ... Chances are you will spend more money on this amp getting it fixed than buying a new one ... Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch
lownloud87 Posted November 28, 2012 Author Report Posted November 28, 2012 possible the output transistors, and the you could always look at this page http://www.bcae1.com...orialcdinfo.htm thanks ill check it out. Someone let the smoke out ... I'd start looking into amplifier repair shops ... Chances are you will spend more money on this amp getting it fixed than buying a new one ... id rather take it apart and fix it myself.i wanna learn how to work on amp and fix them more then i already know how. but thanks Wicked 4 play car club 2002 Chevy 2 door blazer Real soon setup head unit: PTID-8920B subs: 4 12's or 2 15's hevent made up my mind on brand,ported at 33hz amps: for sure two RF 300.4' for mids and highs, 3sixty.2. stuck on wat sub amp ill be using power supply: big 3 1/0, 2 runs of 1/0 power wire and 2 runs of 1/0 ground wire bacc to the second battery, 8awg, 4awg and depending on the sub amp 4 to 1/0 power and grounds for it. speaker wire: 12awg speaker wire and 8awg for subs speakers: 4x6's dash, 6 1/2 components doors, 5 1/4 components kicks, and 6x9's back. all Infinity Reference misc.: 8000k hid low beams/projector headlights, 3/3 lowering kit, D3400 xspower batt up front and rear, ad244 145 amp alternator
severancej Posted November 28, 2012 Report Posted November 28, 2012 Send it to rockford fosgate. Their amp repair is affordable. 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
