How should I wire this?
Ok, I've been out of the game for a while. But finally have a system on the way.
Truck is a 2012 GMC Sierra
Amps- (2) AQ750.1s
Subs-(2) SA-8" V2s D2
Will most likely strap @ 2 ohm
My question is on power
Should I run 1 run of 1/0 and then split in the cab to two 4 gauge runs, or two seperate 4 gauge runs?
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
are you having a battery in the back?
I may throw a small XS if I can fit one in the cab. I haven't measured yet
Amps- (2) AQ750.1s
if you going to have a battery in the back run 1 gauge from your battery to ur battery in the trunk, possibly do big 3 up front, then depending on size of your amps run 4 gauge or w/e they call for to them seperate off battery in the back with both fused bout 3-6 in. from battery?
im guessing. when i ran liike 4 amps i ran 1 pos from front to back to my battery then diff wires to each amp and all
actually many people have more luck when they DON'T strap their amps, so they claim.
but if i were you i'd run 0awg and split it.
therefore if you decide to upgrade, just get a 0awg coupler(look for stinger 0 gauge coupler)
and add on more 0awg!
but accessories can add up so if your on a budget, it would be cheaper to do 2 runs of 4awg.
I have my 0 gauge run to a distro block then 4 gauge run to each amp. Works fine for me.
2005 Chevy Colorado
Pioneer avic-x930bt
Alpine pdx-m12
Alpine pdx-f4
Focal is 165
Focal ic 165
Sundown SA 15 D4
Kicker 0/1 OFC power wire
Kicker 12 awg speaker wire
XS Power D2400
DC Power 270 H/O Alt
Ok I'll be doing 1 run of knu OFC 1/0 to a distro block or battery. Should I fuse the 1/0 at the wires rating, or the amps? The amps have on board fuses
  • Who's Online   0 Members, 0 Anonymous, 723 Guests (See full list)
