Ok well i noticed the other day that when i hit the rear defroster button it just blinks and doesn't come on. Anyone know what the problem might be? The rear window has the lines in it to heat it up.
what kinda car?
did ya check your wires going onto the rear defrost tabs on the backglass?
that is where you should start. then if they are still attached, take an ohm meter and see if there is continuity between the 2 sides.
let us know
Would you have cut any of the wires on the window somehow like if you tinted your window.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
yeah i'm pretty sure its good because the heat still works just the rear defroster doesn't turn on.
In most cars the rear defroster has its own fuse. But you said that the button lit up. So it probably means that the stripes have a short in them. Just take it to the dealer since you have a warrenty. I just changed one in a Jag the other day and charged $600 its a pain in the ass to change. Good Luck man
Mark
99 Eclipse Spyder
Usually it will light up and stay orange but now when i hit it, it just blinks.
  • Who's Online   0 Members, 0 Anonymous, 1085 Guests (See full list)
