How to wire below 1 Ohm?
1 amp per sub at 1ohm is what i recommend.. and you dont have enough electrical to run 2 amps at .5 ohms each you
how many runs of 0 gauge do you have to the back batteries
so you dont have the electrical
the amps will draw about 450 amps each. you will need another alternator and 2 more batteries plus 6 runs of 0 gauge
or the 1 alt and about 6 batteries
if you run the amps at 1ohm it will still be loud. its only a few hundred watts you will see at .5
the reason people wire amps at .5 ohms is to get the rated power after impedance rise.. the amp wont magically make more power just because you wire it to .5 ohms
the amp is rated at 3800 at 13.8 volts at 1 ohm. wiring to .5 will only keep it closer to the rated power vs wiring at 1ohm and rising to 1.5 ohms and getting a few less watts
though your ohms can still rise to 1.5 even wired to .5. there is no way of telling what the impedance will rise to
  • Who's Online   1 Member, 0 Anonymous, 1654 Guests (See full list)
