tacomaguy1 Posted November 29, 2012 Report Posted November 29, 2012 If you want one amp on each.sub and.to be below 1 ohm you'd need dual1 ohm subs Team Flex Issues
lt1jerome Posted November 29, 2012 Author Report Posted November 29, 2012 I posted the question on here during the build about the pros and cons on strapping the amps and the majority of people said they had issues doing it like that so I just kept it simple.
Miguels Posted November 29, 2012 Report Posted November 29, 2012 1 amp per sub at 1ohm is what i recommend.. and you dont have enough electrical to run 2 amps at .5 ohms each you how many runs of 0 gauge do you have to the back batteries my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
lt1jerome Posted November 29, 2012 Author Report Posted November 29, 2012 Yeah I have a shortfall in that department. Only 1 run to the back
Miguels Posted November 29, 2012 Report Posted November 29, 2012 so you dont have the electrical the amps will draw about 450 amps each. you will need another alternator and 2 more batteries plus 6 runs of 0 gauge or the 1 alt and about 6 batteries my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
lt1jerome Posted November 29, 2012 Author Report Posted November 29, 2012 Thanks alot for the info guys. I'll stick with my current setup until I upgrade electrical....Gives me a reason to get some toolmaker dual inputs
Miguels Posted November 29, 2012 Report Posted November 29, 2012 if you run the amps at 1ohm it will still be loud. its only a few hundred watts you will see at .5 the reason people wire amps at .5 ohms is to get the rated power after impedance rise.. the amp wont magically make more power just because you wire it to .5 ohms the amp is rated at 3800 at 13.8 volts at 1 ohm. wiring to .5 will only keep it closer to the rated power vs wiring at 1ohm and rising to 1.5 ohms and getting a few less watts though your ohms can still rise to 1.5 even wired to .5. there is no way of telling what the impedance will rise to my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
