Mt. Hummer Is Getting A Rebuild.
hahaha no no....typically to you thats 500 watts
And clearly ya dont know amps, i love noobs like you who look in the rear of my truck..."HOLY CRAP.....you broke a 50 with 500 watts"
It never gets old
MODIFIED 2001-4000
1 C126848 Laughorn, Brett ( Marrero, LA 70072 ) 156.10 04/23/2008
2 C118639 Taylor, Daymian ( Shreveport, LA 71107 ) 155.80 03/17/2008
3 C123887 Chancey, Derrick ( Houma, LA 70360 ) 155.30 01/03/2008
There ya go, still a state record also....niceeee
actually im not a noob. im guessing its american bass? thats just one that labels those that way.
and i think that 156.7 was on music.
well there are 3 completly differrent names there, what does it prove bro, that you set records with three differrent names?
move a box like the hummer does 5 feet away with 4 12s, with your sunroofopenand the doors open, if you can make a video of it, and I will quite car audio
I dont know what it peaks at but I know its tuned low
hahah you think im not gonna try haha
I dont have a sunroof but ill open all doors
I prolly cant do it but ill give it hell, and im tuned to 35hz
2004 Explorer4 12" Type R500.1(.5 ohm)6cu@35hz153@ 44hz
I said i did 56.1 and showed ya a name that did 56.1
Try 2 and 2 together....need a driver license with that same name?
Any proof ya need i can give
your wrong
146 is twice as loud as 143.
i dont wanna argue but hell im tired and i might as well try it.
http://www.quantumaudio.net/cozmiksubs_spl.htm
Perception of Loudness (20dB = 4x)
Interestingly, our perception of loudness is not the same as sound pressure level. Although the actual formulae
is somewhat complex, as a rough rule of thumb, an increase of 10db SPL is perceived to be approximately twice as loud.
Thus a 20 Db gain would seem to be about 4 times as loud.
And a 40 Db gain would seem to be about 16 times as loud.
http://www.cco.caltech.edu/~musiclab/decibel.htm
It's odd but true that we have a perception of "twice as loud." If you listen to a sound through your speakers and turn up the volume control, you will find that at some point the sound seems "twice as loud." This is already noteworthy! And if you raise the volume 'til the music sounds twice as loud again, you will have taken the music through two increases of about the same power ratio. Each will have been a change of roughly 10 dB.
that rule is wut i have always known. mybe in higher db levels things change but i have always learned that 10 db is twice as loud
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Its ok.....we all had to start somewhere
But with 8000 post i would think it wasnt all wasted on nothin
I misread my bad, Im not knocking your numbers but you cant compare kickpanel to the dash its notthe same.
what are you doing on the dash? db drag legal?
Thats all flawed
If you go from 150 db to 160 db....i guranteeeeee you your not gonna say "Oh, thats just twice as loud"
If youve been around actual meterings and comps youll find this true
Every 10dbs....man.....thats a HUGEEEEE jump to only be twice as loud
But i could be wrong
no need to argue, your wrong, I dont care what you post to back up your theory, its wrong.
add 3 db's to any score you post on the termlab and its twice as loud, ask anyone who competes.
With that setup around 54.5ish on dash
And yeh....im down about 1.5ish from kick to dash...its not the same but its the only org i have down here so thats all i meter in
  • Who's Online   0 Members, 0 Anonymous, 1068 Guests (See full list)
