00 dakota rebuild started! wall is out! update on page 6
got this to replaced my totaled mustang :( it has 3 years/20,000 mile power train warranty (engine,tranny,rear end)
little rusty but i like it (even the color lol )
plans for truck appearance
bed liner/plastidip bumpers (bedliner in the bed and tonneau cover)
black rims (might buy my buddy's 20s)
tint on the windows
HIDs/fog lamps
dual exhaust
black tail lights
all rust fixed
possibly different color using plastidip or bed liner
my plans for audio as of right now (subject to change)
Head unit
i have the kenwood from my mustang still
wire/RCAs
100 feet of sky high car audio 1/0
RCAs will most likely be stinger but them walmart cheapos worked for me last time
Charging/batteries
shooting for a singer 270a but this is subject to change
4 deka group 34s in the back (adding to this if voltage drops below 12.6 full tilt)
1 in the front
amps
soundstream 560.4 for the 4 channel
sub amp has yet to be determined im looking for about 5k @ 1ohm or 2 2500s
mids and highs
2 sets of soundstream tarantula series 6.5s
(all of these will be in the doors only! no A pillar/kicks)
stock location 6.5s in the front possibly some silk domes in the stock location (brand to be determined)
subs
Four 15in Incriminator audio Lethal Injections
down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups
^^ Cant wait to swalllow Ghost's babies
Sounds like it'll be a pretty killer build whether you go with the 15s or the 18s! And I've gotta say, I'm pretty jealous you have a 4 door. I'm trying to keep my back seat in, but I barely have any room for amps and batteries back there with the extended cab!
And just so you know, you can fit a D2700 under the hood without any modifications.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
yeah i was looking at an ext f150 but seen this truck and decided to jump on it
plus the powertrain warranty really helps
18s for sure now.......
Sounds like a pretty good plan! What motor do you have in the Dakota?
136.4 Sealed @ 29hz
4.7l 4 speed auto 4x4 (floor shifter)
thing gets better gas mileage than my 4.3l jimmy did (so far)
******aq200x4 ( deciding if its worth it or not to run 10s in the door im thinking 1 sd2.0 10 in each door for 100-400hz range)
DON"T USE SUBS FOR MIDBASS. the FS on those 10's is at 47 hz., the frequency range will not be where you want it. they'll play that 150 to 400 hz you're planning on like wet paper towels stuffed in a pringles can.
Find yourself some 10" woofers (not SUB woofers) that have a playable range like you're after.
ive seen it done if you seal the sub in the door properly
but yeah its gonna take alot of work to do it right
i think i might just keep my original plans and use the mr6.5s and tweets im not really going for pure SQ so i dont think ill miss the midbass that much as most of my build didnt have great midbass just hella loud highs and good lows
That's a Damn good plan! And I hate u for ur gas mileage. I'm running the 5.2L v8. Amazing 6-14 mpg depending on 4wd and city or highway. Watch ur 4wd tho. Mine is partially engaged at all times. Can't fix it. And where u from? Bottom of doors rust fast around here.
Looking really good tho. Good luck!
Cody C.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Cody C.
yeah doors on the bottom got some rust
im from wisconsin and the vehicle has been here its whole life
1 owner before me
Alright.lemme know how u fix those. I can see light through the holes on the very bottom of my doors and quarter panels.
Vehicle:
Stock Alt
Equipment:
Wire- EB Flex 2/0
