L7 box help
masterbusa2
I'll get some more info but im pretty sure it will fit there's plenty of space back there, there aren't any seats or anything, and it's a dual 4 ohm sub
Edit: there is 32" length from back of console to window, 64" wide 48" high
I love to no how you plane to do that
"Not turned up max" when you gain match not volume set
Because someone with the knowledge to do that
Should have enough knowledge to read the first page of the T-line post witch explains everything you need to now in laymen's terms to build
secondly seens as this is a "customer" build
That means your getting payed for your knoladge and box building skills, right?
So why are you asking for help again?
And in the first post you said rear seat was going back in and now there not?
Who in there right mind would remove the entire back seat for 1 10" sub
Good advice you give there,
to make it easy for you
your amp makes too much power and has insufficient dampening factor to control it, with that much power in a T-line
real options are
get another amp,
get a dual 2 sub
build a sealed box
build a ported box and gain match @ -3db
and thats some good free advice, lest just hope you no what to do with it
Hey dude no need to go on a rant it's my best friend and all he is paying for is the wood and he said it was fine if I attempted a t line for te first time, I'm gaining nothing from this I'm doing it as his Christmas present, now that you mention it I do remmember reading about setting everything a certajnw way I never claime I knew how to build it I only was wondering what would help the sub get the lowest, if he blows it it's on him and he will upgrade but until then I didn't ask the question to hear get a new sub. I simply asked info regarding port length vs the size of the port mouth the difference web though same tune say 32hz with a small mouth but super long port vs large mouth short port length same tune but what would be the difference
Edit: also I was sayig seats staying in if doing a normal ported box, then friend called me up ad said he's fine with removing them conpletly and Doug something bigger the 10 is only temporary eventually going to go with something bigger just trying to get as much flex possible out of a kicker l7 Sorry for any confusion
Just put it in a to spec ported box
Don't wast your time or his money on a tline, just to fry the thing
If you can get a different amp give it a go, but not with what u have,
I'd just go with what works, and works well, and will give you hrs of lessening pleasure,
2cuft net, 24sq" of port @37hz
Edit
And put the seat back in
your still not getting it,
no to 750's
you need like 300rms @2ohm for a T-line
not 750,
that sub is only rated for 450rms ported, (600 sealed) it will take 6-700 ported, but not in T-line,
and i dont think you'll get a massive difference like you want
save the $$$
and do a nice T-line on the next setup, with the right equipment
  • Who's Online   0 Members, 0 Anonymous, 1758 Guests (See full list)
