Alpine Type R power handling
So what my plan was for my next setup in my car was to get 2 12" Alpine Type R's both dual 2 ohm's and run them at 1/2 ohm to my amp....and at 1/2 ohm my amp should be putting out realistically 2000-2500 watts rms, but in light of recent events with my buddies alpine type s 12 that im pretty sure we burnt the voice coil on at 750 rms, got me thinking that maybe 2000 rms watts is a little much for the type R's seeing how there rated at 600-1000 rms a piece and they dont have any options for re-cones.... so im wondering if i should get 2 DVC 4 ohms and run them at 1 ohm and put out about 1000 rms watts which should be perfectly fine on them, and easier on the electrical on my car.....or just look into different subs in general, then thought had crossed my mind to just buy another 15"(which i currently already have) and get a dual 2 ohm and run it at 1 ohm for 1000 rms watts instead of 500 currently
Anyone have some idea's for different woofers that are in a relatively cheapish price range?
lol what amp? why half ohm? just do 1 ohm. all you're doing is stressing your shit more with half ohm.
What generation Type R is it? I had one of the 3rd gens (600 watt model) and i was running at 2 ohms off my BC2000d. It handled it pretty well, but would get a bit smelly on the lows. If you are looking at 3rd gens, I'd just say to set the gain somewhat conservatively and you'll be fine.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
which ever is the newest model, which i believe is the 3rd gens, oh and the problem with my buddies type S we found last night was the remote bass knob(my fault lol) for ease of not having to tear the interior apart we mounted it on the box and the vibrations started cranking the knob to max, and we were playing psyph morrison-all i gotta do is hit her and about 3/4 tilt and all the sudden sub cut out and zero bass, so i check all the outside connections and they were good, so we need to pull the sub and see if the connections on the inside came out or whatever( has happend to use once before) but im pretty its the sub blown because there was a fairly strong and nasty smell coming from the port
i hate to rain on your parade but that amp is rated at 1000 watts. you are not doubling power by running it at .5 either. I wont even touch on the aspect that you will never be able to supply enough juice for that thing at .5 either. class a amp current draw will be through the roof and beyond.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
have you ever seen these clamped? when my dad had his 4 15's in his f250 running 1/4 ohm it clamped 4100ish iirc, and yes i know the amp draw is enormous thats why im kinda vearing away from 1/2ohm load....oldschool soundstream has been very well know for under rating there products.....
ok if you insist. keep on thinking thats the case. when this amp was in its prime 4100 watts was unheard of in an amp of this footprint.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
if you say so, but im going to go off what ive seen with my eyes
I doubt it does 4100 rms, especially when it's old school
Comparing to a modern 3500 rms amp
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • Who's Online   0 Members, 0 Anonymous, 1088 Guests (See full list)
