are crimp connectors on the amp necessary?
Hi, new member here. I've been apart of other forums such as: R6 Forum, S10-forum and a few others.
I decided to finally replace the blown speakers in my 2002 GMC sonoma; and went with a rockford setup due to the cyber monday sales. Adding new dash and door speakers; adding to the kicker L7 i currently have.
The rockford amp i received has terminals for spade connectors (specifically #8 for all 8 of the speaker inputs, power, ground and the remote wire.
I'm just wondering if its necessary to crimp and/or solder on connectors for each and every wire or is it okay to just attach the wire directly to the amp. My only concern is that it may not be secure enough.
Thanks a lot, please let me know if there is additional information i need to provide!
thats an answer i was looking for.
i planned on soldering the speakerwire directly to the speakers but i will go shop around for some spade connectors before i install.
Sorry about the question, again, i just wasn't exactly sure as to the best way to connect to a rockford amp (with the set screw going directly in the middle), the amps i have used in the past have a slightly different method.
Thanks again!
What if the amplifier doesn't have that type of connection. mine just has a recessed hole and a set screw in the side. Is any time of termination required? To me the wires just shoved in looks pretty bad
Current System:
Clarion CZ702
Stock 5 channel amplifier
Infinity Reference 4022i 4"
GRS 6.5"
Audiopipe 1800.1
2 RE Audio SEX V2's In a 4th order ported though the armrest
2003 130 Amp Toyota Highlander alternator
the recessed hole will allow for you to hide the end of the wire jacketing and allow for ample wire inside. if you have terminals that are just little philips screws connectors are a better cleaner way of doing it. however not required by any means.
i personally all ways terminate with some sort of connector when its needed.
NEUMAN
  • Who's Online   0 Members, 0 Anonymous, 1155 Guests (See full list)
