willwork4beer Posted December 9, 2012 Report Posted December 9, 2012 I like some MB Quart products but the 1000.1 only has one 60 amp fuse. I don't think it will do a rated 1000.
CleanSierra Posted December 9, 2012 Report Posted December 9, 2012 Joe, he has a CARAVAN, I do believe more than 2 12" Kickers will fit.... Also, you used his maximum height and width. Are you sure he's going to have 4.5 inches at least between the port and the back hatch? If he doesn't have the room and the box needs to be fired port and subs UP, then the cut sheet is wrong and so are the port dimensions. That box needs redesigned completely in my opinion. Im not the one you want to try to troll. Just a fyi for you.
Joe X Posted December 9, 2012 Report Posted December 9, 2012 I like some MB Quart products but the 1000.1 only has one 60 amp fuse. I don't think it will do a rated 1000. It has got an 80 amp fuse, like many amps the rating is at 14.4 volts (CEA), while somebody should clamp it to double check, in this case the OP needs only 800W to meet the subs rating.
van klan Posted December 10, 2012 Author Report Posted December 10, 2012 I think ill look into a new amp but i love the old kicker punch series lol yeah ill double check the clearance for the port to the hatch If hes tailgating let him pass, pull up behind him and rattle his mirrors off....
van klan Posted December 10, 2012 Author Report Posted December 10, 2012 Yeah the clearance to the hatch wont work its pushing 3-4inches does it matter which way the port faces in conjuntion to the sound? If hes tailgating let him pass, pull up behind him and rattle his mirrors off....
van klan Posted December 10, 2012 Author Report Posted December 10, 2012 And i also have a 2000w lanzar amp but i highly doubt it 2000w hahaha 45 fuse on it lol but just throwin it out there not sure what amp to use i think the mb quartz will be my next buy If hes tailgating let him pass, pull up behind him and rattle his mirrors off....
Joe X Posted December 10, 2012 Report Posted December 10, 2012 And i also have a 2000w lanzar amp but i highly doubt it 2000w hahaha 45 fuse on it lol but just throwin it out there not sure what amp to use i think the mb quartz will be my next buy I have changed the box above to port up, check that at H = 15 you still have D = 19 so that it fits nicely, with a 45A fuse that Lanzar amp will probably do 550-600W, a little more than the RF on a single channel, just to confirm do you have dual 4 ohm coils subs?
van klan Posted December 10, 2012 Author Report Posted December 10, 2012 Cool thanks and yeah they are duel 4ohm wired down to two a peice then tied at the amp to a single channel. If hes tailgating let him pass, pull up behind him and rattle his mirrors off....
van klan Posted December 10, 2012 Author Report Posted December 10, 2012 And yeah it should fit nicely thats why i made the hight 15 because thats where the seat starts to taper back If hes tailgating let him pass, pull up behind him and rattle his mirrors off....
CleanSierra Posted December 10, 2012 Report Posted December 10, 2012 Cool thanks and yeah they are duel 4ohm wired down to two a peice then tied at the amp to a single channel. When you have the subs wired in series/parallel like how you have, tied to a single channel, you're asking the for a 1 ohm load. You need to fix that, because if the amp isn't 1 ohm stable, it will protect or blow. You need an amp that puts out rated power at 1 ohm. If you're on a tight budget get a Hifonics BRZ series amp. Im not the one you want to try to troll. Just a fyi for you.
