gauge cluster swap and mileage rollback questions
i'm thinking of swapping my gauge cluster in my 2000 jeep cherokee from this
to this
from what i am reading it is a straight swap but i would like to hear this directly from some one who has done it. my other question is would it be possible to change the mileage on the new cluster to match my old mileage since the mileage is stored on the cluster. if it was lower i would just jack the jeep up and let it run. but the issue is that most of the ones i find are higher mileage. like over 20,000 miles more.
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
bump anyone?
Theres no way (that I know of, pretty sure on this) to change the mileage on those things... You're kinda stuck with what you got there...
As for swapping them out, there really easy. Completely plug and play. Just take the old unit out and plug the new one in the existing ports. If you need one I can dig around JeepForum and find a writeup... I'm pretty sure I stumbled across a really nice one on there a while back...
1999 Jeep Cherokee SportLifted on 31'sPopcorn Sounds AX6000.1 w/ AA 500.1 "THE F1X" board4 Obsidian Audio OA15's
C pillar wall @ 29hz
^^^work in progress^^^
  • 1 month later...
I know you can order a remanufactured one for GM online and on Ebay that they will set the odometer to whatever you need so it is possible, just never looked into doing it for a Jeep.
The company is Digital Dash Solutions, maybe they can help you get this set properly.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
I would have to see the back of the bezel, but you can change the mileage. just by swaping out the modules, if they are the same. I have done this many times with my civic. I have had 3 different clusters and have been able to keep my original mileage. Mine I just CAREFULLY pulled out the needle of the speedo and then the module on the back unscrewed. Yours might be very different since I have never messed with anything outside of the Honda realm.
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
  • 1 month later...
bump, has anyone seen a writeup on this? i cant seem to find out how to take apart the dash
saw that one, its not for my model and dash though
different again, thats on a grand cherokee which is what i keep finding
  • Who's Online   0 Members, 0 Anonymous, 627 Guests (See full list)
