bump please.
To Slide Sideways Or Not To Slide Sideways?
Head unit: Pioneer AVH-5000DVDSpeakers: 4 Pionner TS-G6842R Amplifier: Alpine MRD-300Subwoofers: 10" JL
if ur amp is two channel most of the time it can be bridged and it will put out twice the power at twice the ohm load.
so say u have two channels 600w rms @ 2 ohms then most likely it can be bridged for 1200w rms @ 4 ohms
just check and see if ur amp is bridgeable before u do it
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Amplifier
2-channel car amplifier
200 watts RMS x 2 at 4 ohms (250 watts RMS x 2 at 2 ohms)
500 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode)
Subwoofer
4-Layer, 4-Ohm Edge-Wound Voice Coil
200 Watts RMS / 800 Watts Maximum Input Power
Would this work out?
yup it says itd bridgeable and puts out 500w rms @ 4 ohms
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
could i wire up 2 woofers?
there both svc,4-ohm.also how would you wire the amplifier to be bridged?
Edited by D_Bass
bad news u cant get a 4 ohm load out of 2 4 ohm svc woofers
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
