box plans for 3sav.2 8's.....single cab f150
bigmescan
alright guys what i have now is 2 8's and im adding another....the dimensions i have are 53x15x7 ....im looking for 36hz.
this is what i have now......i will mount the amps on top of box...and if need be i can go 55long and maybe 8in deep. i still want to fire port to passenger side. and i believe i can get a 4in aero. instead of the aero being in center of box side maybe go the the top of the box
SONY XAV-701HD
RF power 400.4 RF power 1000bd
3 Sundown x8's d2
2004 f150 single cab
2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)
stock batt up fron
BIG 3
http://www.stevemead...-vid-pg-11-922/
http://www.youtube.c.../TheBigmescan74
I would fire it at the B-pillar instead of the up at the roof. I agree that you can get a 4 inch aero but depending on airspace, I might suggest 2 3" if you can.
thats how i have it firing now. the actual flare is 7in but id have to put it at the top of the box on the side so it wont hit magnets.im just seeing if someone can see what they could do with dimensions im giving.with 55in i can still have batt on drivers side and still have 4in from passenger wall. but if i have to i can slot port on the side as well
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
You'll need 1x 3" aero per sub
So
3x3" aeros
2x4" aeros
1x6" aeros
My oppion is with 3 of these
2.2net@ desires hz
On 2500-3000rms @1 ohm
As you'll be 1.33ohm
So
3x3" aeros
2x4" aeros
1x6" aeros
2.2net@ desires hz
You would also have him tune to 28Hz too though ;)
i thought 3d4's would put me at 2.66 and im gonna have to upgrade the amp to probably a t2500.1
and i have no clue what you said bout the 3in aero. can you elaborate please
SONY XAV-701HD
3 Sundown x8's d2
stock batt up fron
BIG 3
P.S. I've been suggesting putting those amps above the box against the rear trim panel for a LONG time now. Glad you are finally getting the most of your space!
On another side note, which coil configuration are you running on the subs? D4 or D2s? D4s with 3 subs puts you at 2.33 and dual 2s would put you at the 1.34 like John said.
*Edit- I was typing before your response was there. I answered your question before I had seen you asked it?
To get proper sq. inches per cube on port area, he meant that each sub needs a 3" aero to satisfy GOOD port area per cubic foot.
  • Who's Online   0 Members, 0 Anonymous, 998 Guests (See full list)
