Rev. Wrath Posted December 11, 2012 Report Posted December 11, 2012 Also could be the Idle Air Control Motor. Ford I.A.C. motors are notorious for getting weaker with age. The motor starts to slow down and will usually cause the car to die imediatly after starting, but I suppose high idle could be possible too. Either way it's something else you could look into.
TylerParrish Posted December 11, 2012 Author Report Posted December 11, 2012 If they don't figure out what it is by tomorrow, I'm just gonna ask em for my car back and finish the work myself cause I'm tired of not having my car. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
mikelbolton Posted December 11, 2012 Report Posted December 11, 2012 I agree, check the IAC, although this usually causes rough idle, even after heating up. It is not out of the ordinary for newer cars to idle higher when first cranked up. Cars with heated oxygen sensors have to get to operating temperatures faster to keep the O2 sensor from fouling out. Once it reaches normal operating temperature, the idles should return to normal. 3k sounds a little high to be normal to me though. Does the car throw any Diagnostic codes? Typically if you have a Throttle Position Sensor issue, the CEL will illuminate. That can also cause the car to die when rolling to stop signs, and misfiring under acceleration. I'll check and see if there are any TSBs on high idle, when I get back to the house. 2011 Chevrolet Aveo(click for build log)Clarion NX-603SKAR 4500.1DIraggi 320A alt Knukonceptz 1/0 Kollosus Fleks Cable8 AWG Sky High Car Audio OFC 1/0- Sky High Car Audio 2- XP3000 XS Power BatteriesSMD VM-12- 12" Ascendant Audio Mayhems Toolmaker Fuse block Toolmaker Bus Bars (Last Season scores 1-15" Mayhem) 145.2 dB- Sealed @ NSPL World Finals (9/28/14) 148.1 dB- Hardcore @ NSPL World Finals (9/27/14) 150.23-- Hardcore on 4500 Watts!!!! New Build (2015, 2-12" Mayhems) 146.9- Sealed on dash 149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
mikelbolton Posted December 12, 2012 Report Posted December 12, 2012 I don't see any Tech Bulletins regarding rough idle. 2011 Chevrolet Aveo(click for build log)Clarion NX-603SKAR 4500.1DIraggi 320A alt Knukonceptz 1/0 Kollosus Fleks Cable8 AWG Sky High Car Audio OFC 1/0- Sky High Car Audio 2- XP3000 XS Power BatteriesSMD VM-12- 12" Ascendant Audio Mayhems Toolmaker Fuse block Toolmaker Bus Bars (Last Season scores 1-15" Mayhem) 145.2 dB- Sealed @ NSPL World Finals (9/28/14) 148.1 dB- Hardcore @ NSPL World Finals (9/27/14) 150.23-- Hardcore on 4500 Watts!!!! New Build (2015, 2-12" Mayhems) 146.9- Sealed on dash 149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
TylerParrish Posted December 12, 2012 Author Report Posted December 12, 2012 I agree, check the IAC, although this usually causes rough idle, even after heating up. It is not out of the ordinary for newer cars to idle higher when first cranked up. Cars with heated oxygen sensors have to get to operating temperatures faster to keep the O2 sensor from fouling out. Once it reaches normal operating temperature, the idles should return to normal. 3k sounds a little high to be normal to me though. Does the car throw any Diagnostic codes? Typically if you have a Throttle Position Sensor issue, the CEL will illuminate. That can also cause the car to die when rolling to stop signs, and misfiring under acceleration. I'll check and see if there are any TSBs on high idle, when I get back to the house. best bet is throttle position sensor, that's what i told em to check first, now if they do or not, idk, but if they aren't callin me by tomorrow sayin its done, ill pay em for what they've done and finish the rest of the work myself. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TonyD'Amore Posted December 12, 2012 Report Posted December 12, 2012 *IAC (idle air control) valve dirty or damged *Vacuum leak
Nikitaaa Posted December 12, 2012 Report Posted December 12, 2012 My car goes to about 2k at a cold start up and then after about 5 mins or so it drops down to normal idle. Idk... I always thought it was normal 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
02 GAGT Posted December 12, 2012 Report Posted December 12, 2012 I would say its a vacuum leak cause my car would idle at 1000 RPM when it's normal idle is 650 RPM, turns out a fitting popped outta the valve cover when I did the LIM, so check for vacuum leaks by spraying carb cleaner around the LIM and UIM and the TB, if you don't understand look at Scotty kilmers video how to check for a vacuum leak
TylerParrish Posted December 16, 2012 Author Report Posted December 16, 2012 It was the IAC my cars finally fixed and I can start working on it again when I go get it out What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
OrionStang Posted December 19, 2012 Report Posted December 19, 2012 I had a 2000 V6, IAC went bad and the car idled high lke you explain. With the car running, I unplugged the IAC and the idle would drop, plug it back in and the idle would jump back up. $84. SMD Super Seller My Feedback Thread
