FamilyB4Others Posted December 14, 2012 Author Report Share Posted December 14, 2012 Looks nice and clean so far. I like matching amps Thank you, wish I could've put the 300/2 on top of the 1000/1 but it would block the port hole and try laying it side by side but was to long by an inch Heres where it sits temporary... Extra LED strip I ran in the trunk, wire to turn on factory when trunk is open. Link to comment Share on other sites More sharing options...
will77530 Posted December 14, 2012 Report Share Posted December 14, 2012 nice looking install Link to comment Share on other sites More sharing options...
FamilyB4Others Posted December 15, 2012 Author Report Share Posted December 15, 2012 nice looking install Thanks little update, Focals being installed Back was hitting door, so I had to cut out a MDF spacer. I then had to cut the door panel becuase it was hitting due to the MDF spacer forcing it out a bit After cutting it Tweeters went into the stock location on the top corner dash. Nothing special so no pictures. Done Video doesn't do it justice on the sound quality. Link to comment Share on other sites More sharing options...
Rev. Wrath Posted December 15, 2012 Report Share Posted December 15, 2012 Let us know how those fans work out for you. I was thinking of using those when I rebuild my trucks system, so I'd like to know what you think. Also, your video is set to private... Link to comment Share on other sites More sharing options...
FamilyB4Others Posted December 16, 2012 Author Report Share Posted December 16, 2012 Thanks for the heads up on the video being private, it should work now. As for the fans ill try get a video of them working for you. Their motor noise is a bit loud for me. When the stereo volume is all the way down you can hear motor on the fans...Maybe I'm to picky but ill get over it. Overall they do the job. Link to comment Share on other sites More sharing options...
FamilyB4Others Posted December 17, 2012 Author Report Share Posted December 17, 2012 Update, port threw rear seat, armrest Cutting it out Port rings to clean up the hole Test fit Vinyl wrap time Install time Back of the seat Front of the seat From outside view of port Done. Link to comment Share on other sites More sharing options...
FamilyB4Others Posted December 17, 2012 Author Report Share Posted December 17, 2012 Alpine 9886 Rear trunk LED strip ad on Setting gain with the DD-1 New port coming alone. More round over and 3 inches longer total 8" x 18" to tune a little higher. Also going plastic dip it for looks, hopefully it doesn't affect any dbs being resin Link to comment Share on other sites More sharing options...
FamilyB4Others Posted December 19, 2012 Author Report Share Posted December 19, 2012 Video of the fans as promised. http://youtu.be/y59s52pYRxU Link to comment Share on other sites More sharing options...
Kyblack76 Posted December 19, 2012 Report Share Posted December 19, 2012 SUBd Not sure how i missed this. I had a build in basically the same care. Wondering how you roll with yours. Best of luck,.. looks great so far. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
FamilyB4Others Posted December 19, 2012 Author Report Share Posted December 19, 2012 SUBd Not sure how i missed this. I had a build in basically the same care. Wondering how you roll with yours. Best of luck,.. looks great so far. What did you have in it? I'm always looking for more ideas. Thanks for the compliment Link to comment Share on other sites More sharing options...
