fox_racin4 Posted December 12, 2012 Report Posted December 12, 2012 So, my amps are in the BED of my truck.. Been thinking about getting a small 12v heater so that they arnt in the super duper cold Thoughts? 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
KnockinthaStreetzof608 Posted December 12, 2012 Report Posted December 12, 2012 As long as there no ice on it, wouldn't it be a good thing if they amps are super cold? CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
fox_racin4 Posted December 12, 2012 Author Report Posted December 12, 2012 Im talking like -5 and such Going from colt to hotbwill create mostier Do not want lol 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
KnockinthaStreetzof608 Posted December 12, 2012 Report Posted December 12, 2012 Wouldn't the heater create the same issue, unless u keep it on 24/7 kinda when u put a glass of water with ice and 5mins later the moisture outside the cup, I did alil install for my dad just a 200.4 in the bed of his truck never had an issue, but ur Canadian so maybe its alil colder there then here in Wisconsin CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
fox_racin4 Posted December 12, 2012 Author Report Posted December 12, 2012 Would be on 24/7 It was fine last year but always wondered 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Swordlordboy1234 Posted December 12, 2012 Report Posted December 12, 2012 This is interesting... I'm in Florida so I have zero experience with cold...but what comes to mind when you mention this, is those cups that have a air pocket between the surface holding liquid and the surface that you hold the cup.. No matter the two tempatures, even ice in the cup while the cup is in the sun.... There is no condensation. Maybe if you took from this principle and tried to build an air tight area for your amps? I mean normally you would want them to reach lots of air, so they stay cold but I don't think cold is your problem... And wouldn't the amp create its own heat? All you would have to do is stop moist air from reaching the amp. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
