Aero Port Configurations
One Way
id do 2 cubes net with a single 4" port if it's strictly a daily box. 2 10's is an awkward airspace to use aero's with. If it were 2 12's, I'd say rock 3-3.5 cubes net, throw a 6" areo in it and call it a day. {My new box will be my 7th aero port box}
1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
Port Area on an aero is determined by the diameter of it, if you want more port area you're going to have to use a bigger one or add another 6" or do a multiple 4" setup for it, the length of the port only determines the tuning. I may be wrong though because that's what I've gathered up from researching so its not a definite answer. My box is about 2.3 cubes tuned to 35hz with a 4" aero that's 10" long with no port noise and sounds great, just a little bit of experience I've had with mine
1898070_635754349830843_1457278514_n_zps
What do you mean it's a awkward airspace for aero ports?
And I tried multiple 4" and even 6" but it was all way too much
that's exactly what i mean.lol. there is no "great" combination for ~2 cubes
So around how much do you like to give for port area?
1000 per square inch. Should be plenty.. :D haha I haven't ran areo so I wouldn't know but I'm going to guess they will suggest 10 to play it safe.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
depends on goals. daily setup, I'd say anywhere from 6-9/10" per cube. spl 10-14ish maybe depending on application
So you think that my box at 9 per cube would be sufficient??
absolutely
  • Who's Online   0 Members, 0 Anonymous, 1819 Guests (See full list)
