Neckbeard Posted December 22, 2012 Report Posted December 22, 2012 I have used this program in the past, and i just reinstalled it, is it OK to use? im pushing my GTX 550Ti to 1000Mhz, am i gonna harm anything? Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
kickass audio Posted December 22, 2012 Report Posted December 22, 2012 its just fine to use but id recommend getting msi kombuster to run a graphics stress test on your computer. if while running the test at your highest resolution capable by the display you encounter any image breakup or lagging you need to turn down the clock frequency a little at a time until it resolves and you have a steady picture. I have a dell xps l702x overclocked from the stock of core at 440, shader to 880, memory at 675 to having it up to 748 for the core, 1496 for the shader and 1000 for memory. It used to run warmer but i replaced the stock heat compound with antec nano diamond and my fan is usually on minimum speed with normal use and with minimal use the fan is almost always off. You will be just fine and will find a little bit of improvement as a result but not too much. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Neckbeard Posted December 22, 2012 Author Report Posted December 22, 2012 where can i get kombuster? cant find a download Build log, Super slow!!: http://www.stevemeadedesigns.com/board/topic/168096-slow-neckbeards-1970-opel-gt/
beaker Posted December 22, 2012 Report Posted December 22, 2012 I use EVGA Precision Tune. I like the custom fan maps you can do with it. Rivatuner is what I used before that.
