Pasta Prime Posted December 23, 2012 Report Posted December 23, 2012 Did you unplug MAF with it off and start it unplugged? New build coming........ YouTube:http://www.youtube.c...6?feature=guide Old Build Log: http://www.stevemead...d-on-the-cheap/ Old Screen name: Redrebel66
donovanl12 Posted December 30, 2012 Report Posted December 30, 2012 What year and model? Is there an ignition control module ICM?
ric006 Posted December 31, 2012 Author Report Posted December 31, 2012 its a 97 ford thunderbird and i replaced the MAF, IAC, found a bad purging valve selinoid and replaced that and found and exhaust leak fixed that problem still persist
ric006 Posted December 31, 2012 Author Report Posted December 31, 2012 now after all this work bank 1 trim is the only side that looks high on both ST and LT 8 & 12 and bank 2 is 5 & 9 in park position
ric006 Posted December 31, 2012 Author Report Posted December 31, 2012 those trims are wrong took new readings
ds1919 Posted January 5, 2013 Report Posted January 5, 2013 grounds are all good? Also I wonder if it has anything to do with vacuum/tranny area...I know you already checked all the vacuum lines....
STEvil Posted January 5, 2013 Report Posted January 5, 2013 clean under distributor cap MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
R James Trapp Posted January 5, 2013 Report Posted January 5, 2013 ^^coil pack. No distributor. What engine is it in the thunderbird? I to have a snap on solus and it is an amazing tool. This could be a tough one friend. By chance have you done a compression check of the cylinders? I'd pull the plugs and see what they look like. Kind of sounds like the puddle was just a coincidence . Water would have evaporated by now. You know starting fluid works good also for finding vacumn leaks. The smoke thing isn't a dead giveaway every time. Still might have a crack in the hose that the smoke couldn't get out of.
ric006 Posted January 5, 2013 Author Report Posted January 5, 2013 grounds are all good? Also I wonder if it has anything to do with vacuum/tranny area...I know you already checked all the vacuum lines.... Yes grounds are all good i even added more the tranny was looked and and there is no vacuum leaks clean under distributor cap Replaced Coil packs both sides ^^coil pack. No distributor. What engine is it in the thunderbird? I to have a snap on solus and it is an amazing tool. This could be a tough one friend. By chance have you done a compression check of the cylinders? I'd pull the plugs and see what they look like. Kind of sounds like the puddle was just a coincidence . Water would have evaporated by now. You know starting fluid works good also for finding vacumn leaks. The smoke thing isn't a dead giveaway every time. Still might have a crack in the hose that the smoke couldn't get out of. Its a 4.6, i did spray all around with starting fluid no idle rise or decrease so im putting the vacuum leak out now and i did replace all vacuum hoses in the engine bay even to the EVAP system most of my hoses were brittle so it was on like 10 bucks to replace all. other than that my fuel trims are in the - now so i know there is no vac leaks just still having the probe with it in gear
R James Trapp Posted January 5, 2013 Report Posted January 5, 2013 So what about a compression check? How many miles on it? The snap on scanner you showed a picture of, can you put the cylinders on a graph with that and watch the spark and injector pulses? Try to see if there's a cylinder dipping on either or both of those?
