What's the frequency response on the neo 6.5's?
I'd like to use them as a component setup, are they suited for a 2 way setup?
Also, is there a recommended crossover that can handle the 100w rms?
I'd like to use a sax 125.4 to run the 6x9's I already have plus the front 6.5's in the door. Adding new speaker holes isn't possible, I want to completely retain stock look.
If you're feeling DOWN & OUT, it's time to get UP & IN
Although I can't really answer your question, I do know that sundown released their component set. Just a suggestion.
2 Sundown Audio SA-10s
Box built by Speed of Sound
Kicker 1500.1
Infinity Ref 475a
Rockford Fosgate T1682c 6x8s
Pioneer Premier DEH-510UB
XS Power D6500
Stock 130amp Alt
Big 3
Build Log
I did see the component sets, but they're only listed at 65w rms. Seems like I'm leaving a lot of available power on the table.
run tweeters and the 6.5s on their own channels active. you wont need the 6x9s. if you still feel the need to, then run them off your deck power.
TEAM SUNDOWN HAWAIIHAWAIICARAUDIO.NET
150Db Club
160Db club in the future
I see krakin as a threat
For the NeoPro 6.5s freq response is about 60hz to 4,000-5,000hz, they really drop off after 6,000 hz which anyways most tweeters are already playing in that frequancy. So if you have a tweeter such as a "Pro Audio" style super tweeter like say Seleniums that dont like to play to low in the midrange the neopro line will match up great with them.
The 60hz frequency is tested in an open freeair style application (as if it was in your door), If you build sealed fiberglass pods for the neopro drivers they will play a little lower and be safe doing it (but you must also take in the power your throwing at them). This line of speakers where made to be like a OEM door speaker where it is played in a open door that is not sealed, they will play much lower then your other types of "Pro Audio" speakers (again selenium, they lack midbass something fierce), not the case with the neopros when they are even used in a freeair application.
The 8inch neopros are asked to be crossed over at 70hz, both the 6.5s and 8s have a 2inch voice coil, same suspension and power handling, while the 10inch neopros use a 2.5inch voice coil and a slightly higher rms rating due to the larger coil.
Personally I would run the neopro speakers and whatever tweeters you chose to be ran active like others have said. So that means a 4channel amp would run 1 neopro per channel on 1 and 2, and 1 tweeter per channel on 3 and 4. Of coarse you could wire 2 speakers or tweeters per channel if you wanted to lower the impedance a little bit.
Here are some Neopro 8s and a pair of slenium st-400 tweeter I played around with powered by a sundown 100.4D ran active. IIRC I had channels 1 & 2 bridge to the mids at 4ohms (2ohms per channel), and the same for 3 & 4 powering the tweeters to get more power out of the amp instead of wiring the amp at 8ohms per channel since all speakers and tweeters are 8ohms. So the amp was doing ruffly 320watts per set of bridged channels, or 160watts rms per speaker. So you know the neopros are strong!
http://www.youtube.com/watch?v=vCwiuBZlLBU
Here is the response graphs from sundown for the neopros
Edited by Audiofanaticz
  • Like (+1 Rep) 3
  • 3 weeks later...
@Audiofanaticz
NEED HELP.... ok im doing a sundown build and will be running 6.5 neopro and 4 Rockford fosgate T1 tweeters. do you think i would need a crossover for them if im running my mids and highs off one amp?
  • Who's Online   0 Members, 0 Anonymous, 552 Guests (See full list)
