Fi SP4 d2 on 3k box advice
OrzechNJ
ok.. but if I get D2's can I still run it at 1 ohm from 2 amps ? or its impossible
ok .. I go with d2s than and save up on the 3k amp... thanks for help
please read what kranny posted
HUH? this thread is a clusterfuck.
2 amps to 2 subs. you want 1 ohm per amp. get d2 coils. parallel. done. end thread.
edit: 1 amp to 2 subs. 1 ohm. d1 coils. series parallel. end thread again.
I go with d2's on one 3k amp on 1 ohm..
just ordered 563.24 total ..
are you fucking illiterate? good luck wiring to 1 ohm with 2 d2 woofers.
edit: hope to god "d2's" doesn't mean two d2 woofers. otherwise you just screwed yourself.
I wanna run ONE sub on ONE amp at 1OHM!!
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
Then you need to buy 2 3k's!!!
Right now you are going to wire it down to .5 ohm
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
one sub to one amp?? you need dual 2 to run it at 1ohm
It depends what you're wiring it to. if you want to wire it to 1 ohm, you want D2's. If you're wiring it to .5 or 2 ohms you'll want D1's. Depends on what the amp is stable down to or if you're strapping it.
yes. ONE d2 sub parallel on ONE 3k amp will give you 1ohm.
from this I understood that I need Dual 2 coils to run it on single amp at 1ohm !!!!!!!!!!!!!!!!!!!!
  • Who's Online   1 Member, 0 Anonymous, 1446 Guests (See full list)
