purplesyrup Posted January 2, 2013 Report Posted January 2, 2013 Last time I visited they're site they were still kinda lacking in the super powerful amps, just revisited, only thing is, it does not say anything about being built in the USA on the site, so im wondering if they are just coming from another place like where DD, AQ, Crescendo, DC, Sundown, are getting they're amps from. If thats the case they are all way over priced compared to the brands listed. Anyone have any input on that? If they were made in the USA and true Zapco quality, that ZX6.5KD looks puuurdy nice. Some one did claim that John at zapco has gone to great lengths to ensure what he feels is the best combination of internals input/output, but theres always a story behind each companies product whether they made it or not. If these were made in house by zapco, that would be shweeet. Mono, 1 ohm: 1 x 14500 Watts (12 volts) Mono, 1 ohm: 1 x 20000 Watts (14.4 volts) Mono, 1 ohm: 1 x 22000 Watts (16 volts) T.H.D. + Noise: <1% @ 1 ohms. SPL competiton class-D mono block amplifier -Four huge MOS-FET PWM power supplies -Double sided through hole epoxy PCB -24dB/oct variable crossover -Variable 24 dB low pass (LPF) crossover -Variable 12 dB bass boost equalization control -Variable 180 degree adjustable phase shift -Variable 24 dB subsonic filter -Efficiency : 86% @ 4 ohm, at 100Hz -Multi-way protection circuitry (thermal/over current/speaker short/speaker DC protection) -RCA line input and line out -Heavy duty copper layer double sided epoxy PCB -6 x 0 Gauge (AWG) battery input connectors -Efficiency: 86% at 4 ohm, 100 Hz -Tested voltage & THD : 14.4V & < 0.5% THD -Operating voltage: DC 10V ~ 16V -Wired remote control -Dimensions in Inches : 11(W) x 6(H) x 38.5(L) $9,999
2loud4uboyz Posted January 2, 2013 Report Posted January 2, 2013 Sweet mother of car audio. I've alway had a soft spot for zapco . Good fine. $$$$$1000 for this great deal. My bad ( $10,000 makes more sence now.) Thanks for not bashing me.
purplesyrup Posted January 2, 2013 Author Report Posted January 2, 2013 $10,000, not $1,000 lol The 6.5k, if actually made in the US would be worth every penny at the $2,500 retail. Those are straight up SQ amps. And Zapco has always been known to use only the highest grade of internals you can get, which is why they are pricey.
zydrix Posted January 2, 2013 Report Posted January 2, 2013 I'll take 20! My build 98 s10 2.2 3 american bass HD 15s with psi soft parts. (on there way here) atomic at-3000.1 (soon) 146.2 outlaw @39hz., bad alt an bad batt when termed (old 2 12" build) alpine 6.5s in doors infinty 4x6s in dash. clarion cz201 HU. mechman 240a H/O alt stuff i still need. SHCA 2/0 wire SHCA 1/0 to 2/0 adapters Atomic AT-3000.1 Lots of sound deadner new mids an highs, still debating on what to do. A few Deka g31 batts.
ChevyBoy95 Posted January 2, 2013 Report Posted January 2, 2013 6 1/0 inputs..... Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
purplesyrup Posted January 2, 2013 Author Report Posted January 2, 2013 6 1/0 inputs..... hahaha thats awesome
purplesyrup Posted January 2, 2013 Author Report Posted January 2, 2013 Ive been searching for a pic of the other side of the amp, 38,000 watts strapped at 2 ohm
Jessica Posted January 2, 2013 Report Posted January 2, 2013 -Dimensions in Inches : 11(W) x 6(H) x 38.5(L) that like 1.4 cuft +/- amp. lol edit math Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
AA98hoe Posted January 2, 2013 Report Posted January 2, 2013 Looks like a old ab1000 which some extra inputs.. Is this Korean based since zapco moved its production overseas TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
purplesyrup Posted January 2, 2013 Author Report Posted January 2, 2013 Looks like a old ab1000 which some extra inputs.. Is this Korean based since zapco moved its production overseas Well shit, thats not what I wanted to hear, Now the pricing seems sky high.
