mdegen Posted January 4, 2013 Report Posted January 4, 2013 I have a JBL GTO 7000.1 mono amp 700 wattsat 2ohms and 425 at 4 ohms. its running a Powerbass M series 12" SVC woofer 375 watts rms 4 ohms. what is the best way to tune my amp for the sub?
Noel989 Posted January 4, 2013 Report Posted January 4, 2013 Dd-1 or oscope to set the gain bass boost to 0 low pass filter to about 80 Sub sonic filter to about 30 Build Log - http://www.stevemead...-cruiser-el-pt/
Watch the bass Posted January 4, 2013 Report Posted January 4, 2013 If you have luck you can find someone near http://www.stevemeadedesigns.com/board/topic/137758-smd-audio-tools-map/ "in the abundance of water, the fool is thirsty" Bob Marley
Swordlordboy1234 Posted January 4, 2013 Report Posted January 4, 2013 I love these gain questions. You have 2 choices dd1 / oscope and do it right..... Or Tune by ear and hope for no magic smoke...... Point is a trained audio file SQ judge ear can hear less then 5% distortion... Normal people can ear 3-10% distortion You can see 1-2% distortion on an oscope (depending on variables) Dd1 will detect less then 1% distortion indefinitely. Hint tony d amor has a video showing an oscope vs a dd1 when the track fluctuates from distortion (imbedded in the track) to a clean dignal. Oscope looks the same through out the track... But the dd1 finds it. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
