z_jarad Posted January 5, 2013 Report Share Posted January 5, 2013 Well I have a S10 running on a yellow top, and i need to upgrade my current setup is a 1500.1 orion xtr amp along with a rockford 400.4. I have one run of 1/0 awg and stock alt. I also hope to add another 1500.1 what batteries would fit my needs and also what size alt should I look to run with them thank you for help. Quote Link to comment Share on other sites More sharing options...
will77530 Posted January 5, 2013 Report Share Posted January 5, 2013 whats the amperage on your stock alt...start with a big battery under the hood and do the big three Quote Link to comment Share on other sites More sharing options...
corona_jeff Posted January 6, 2013 Report Share Posted January 6, 2013 I would start by replacing the current battery under the hood with a d3400 and see what the voltage does and go from there. With your current 1500watts you shouldn't need anymore then then that Quote Link to comment Share on other sites More sharing options...
