Made a cover out of a flower pot, seems good reset light and went for a drive, guess well see in a while
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
so my check engine light came on in my 2000 integra
first things first grabbed the code ready and got 5 codes :(
p0420 - catalyst system efficieny below threshold bank 1
p0300 - random / multiple cylinder misfire detected
p0302 cylinder 2 misfire detected
p0303 cylinder 3 misfire detected
p0304 cylinder 4 misfire detected
anyone have any experience with this, just changed the spark plugs but not sure on the first code?
This man is a certified Acura mechanic I believe. Extremely helpful and informational.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
cat codes are dependent off of readings from the oxygen sensors and mass air flow sensor if it is equipped with one originally. Misfire codes need to be dealt with b4 even thinking about looking at a cat problem as they can cause all kinds of false codes to pop up emission related.
I suggest you find an actual scanner and someone that knows what they are looking at with the pids rather than just a code reader. Can't usually see dick on the data stream on a code reader and if you can the data stream reading generally isnt fast enough to get a real idea as to whats going on.
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
thanks guy really appreciate the help, i reset the codes after i dried the air filter and changed spark plugs and took it for a drive, seems to run fine and the light hasnt came back on yet. if it does im going to go get a proper scan to figure it out!
meanwhile check out my cover for my filter, just a flower pot and drilled some holes in it, near perfect fit
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
