so my check engine light came on in my 2000 integra
first things first grabbed the code ready and got 5 codes :(
p0420 - catalyst system efficieny below threshold bank 1
p0300 - random / multiple cylinder misfire detected
p0302 cylinder 2 misfire detected
p0303 cylinder 3 misfire detected
p0304 cylinder 4 misfire detected
anyone have any experience with this, just changed the spark plugs but not sure on the first code?
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
Is it the Vtec or regular B18 LS?
How does the car run? Is it lacking power?
Did you only change spark plugs, or did you do them with wires? If not replace distributor cap, rotor, and wire and see how the car drives.
If the mis-fire is bad and going long enough is can damage your converter. If converter gets cloged is will cause the car to mis-fire.
If i remember i think Honda/Acura had problems with the distributor going bad.
If it's worth building, it's worth over building.
NGK plugs AND the blue NGK wires are what hondas and acuras love most. If thats not what you have in it, I suggest you you do as MOST ignition problems would be solved with that brand on that car.
You said plugs are what you just changed, so thats the first thing to do
well my dad checked out the car and said its running fine and havnt noticed anything performance wise being affected so im thinking its my air intake and my cf hood because its got vents all over it and the filter was soaked this morning
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
power seems fine, car starts fine, so im blaming the cold air intake and my hood as its got huge vents in it so it was just getting soaked
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
if thats the case you should definitely mold a box over it. Last thing you need is a hydro lock.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
yeah gonna work on that!
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
just lettin you know too man, thats a short ram you have not a cold air....cold air is much longer than that pipe and usually tends to bend towards the ground. Short ram sits right in the engine bay where all the hot air is.
i know just so use to saying cai
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
