Joe X Posted January 7, 2013 Report Posted January 7, 2013 Thanks I'll try to wrk with this cause I still about 2 more inches so my amp can sit their Which if I extend it externally I'll keep the same volume but will lower the tuning a bit right? If you give me your max dims you can work with in a way your amp fits I can change the above to what you need, just bear in mind that the port needs some free airspace in front of it (1 1/2" in this case) to work properly.
Noel989 Posted January 7, 2013 Author Report Posted January 7, 2013 Max dimension Lengt 25+ no more than 30 Width 12 Height 12 If you need to add more add to the width And if you've seen the second picture I posted thats how I want to look So the port has to extend 3" out so my amp can flushed mounted in their Don't care if the amp is hanging out on the opposite of the port I can add more wood to make look goog Build Log - http://www.stevemead...-cruiser-el-pt/
Noel989 Posted January 7, 2013 Author Report Posted January 7, 2013 http://www.dcsoundlab.com/35k.html Here's dc site I left the measurements in my car But basically adding like .5 of an inch to their dimension for the heat sink But I'll post them up later today cause I'm falling asleep Build Log - http://www.stevemead...-cruiser-el-pt/
Joe X Posted January 7, 2013 Report Posted January 7, 2013 Max dimension Lengt 25+ no more than 30 Width 12 Height 12 If you need to add more add to the width And if you've seen the second picture I posted thats how I want to look So the port has to extend 3" out so my amp can flushed mounted in their Don't care if the amp is hanging out on the opposite of the port I can add more wood to make look goog Ok so I changed the above so depth is below 12" since you apparently want to put the amp on the back of the box.
Noel989 Posted January 7, 2013 Author Report Posted January 7, 2013 Max dimension Lengt 25+ no more than 30 Width 12 Height 12 If you need to add more add to the width And if you've seen the second picture I posted thats how I want to look So the port has to extend 3" out so my amp can flushed mounted in their Don't care if the amp is hanging out on the opposite of the port I can add more wood to make look goog Ok so I changed the above so depth is below 12" since you apparently want to put the amp on the back of the box. Not on the back It will go infront were the port goes The amp is 10" tall plus .75x2 for the wood thickness is 11.5" so 12" is good Amp is 3" width so the port will extend 3" so it can sit their flush Amp is 23" long, here if it has to be shorter or longer it doesnt matter cause I can add some wood to extend it according to how much the amp is sticking out Build Log - http://www.stevemead...-cruiser-el-pt/
Joe X Posted January 7, 2013 Report Posted January 7, 2013 Most common aimings on your type of vehicle is port firing at the rear gate and sub firing also at the rear gate or port firing at the rear gate and sub firing up. You cant do port/ sub on the same face if you are installing the amp there so where is the sub going to be?
Noel989 Posted January 8, 2013 Author Report Posted January 8, 2013 I re did it how does this look? Build Log - http://www.stevemead...-cruiser-el-pt/
Noel989 Posted January 8, 2013 Author Report Posted January 8, 2013 Most common aimings on your type of vehicle is port firing at the rear gate and sub firing also at the rear gate or port firing at the rear gate and sub firing up. You cant do port/ sub on the same face if you are installing the amp there so where is the sub going to be? I'm not Port back sub up I just need the port extended externally about 3-4 inches Build Log - http://www.stevemead...-cruiser-el-pt/
Joe X Posted January 8, 2013 Report Posted January 8, 2013 You've got the idea, personally I think it's too much trouble to run the port partially external to have it flush with the top of your amp but if that's what you want then you just need to go get some wood to start!
Noel989 Posted January 8, 2013 Author Report Posted January 8, 2013 Why is it or why would it be too much trouble? Does it have to do with box? Or the building part? Build Log - http://www.stevemead...-cruiser-el-pt/
