with 2/0 you should be fine
ok thanks, and is there like a strong slim battery any1 knows of i can fit under the seat of my truck? i dont have room behind the seat or really anywhere else, thx
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
Well for that i would recommend this its small and is really strong hell i even have one in each of my quads this check out the stats on that one if not they have ones that just get bigger from there
can i lay that down? and will 1 of those, with my stock battery and alternator be ok? if i use the 2/0, do big 3 and yea yea
My F-150 Build
What kind of battery do you have stock it should be enough if for some reason it isnt enough you can put a Kinetik 1400 or whatever will fit up front but you should be just fine
its stock battery, stock alternator, if my lights dim with the 2nd battery then i can just upgrade the front battery, and if that dosnt help, a better alt should
My F-150 Build
Ya i think you should be fine with just that back battery
ok, and can that battery lay down on its side, i just looked, i dont have room for it to stand up, so i would have to lay it down and hope it fits
My F-150 Build
definitely go with the kinetik, you should be able to lay any of those down.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 1599 Guests (See full list)
