KyLoGreen Posted January 11, 2013 Report Posted January 11, 2013 I was looking at these amps and saw that they were pretty cheap and was wondering if they perform good? I have a HDC312 sub and was wondering how the brutus brz1200 would perform at 1ohm thanks
jfoodstamp Posted January 11, 2013 Report Posted January 11, 2013 There are plenty of threads on this . I am a Hifonics fan. The brutus is a good amp for the money and will deliver rated power. If you can step your budget up that woofer will handle the 1700 with no problems
KyLoGreen Posted January 11, 2013 Author Report Posted January 11, 2013 Do you think I should spend the extra money to get a soundque 1200d?
Skrilla Posted January 11, 2013 Report Posted January 11, 2013 Do you think I should spend the extra money to get a soundque 1200d? I would. 2 HDC3 18's AQ2200D
KyLoGreen Posted January 11, 2013 Author Report Posted January 11, 2013 Ok I was thinking the same thing but the website says the soundqube is stable to 2ohms does it handle 1ohm ok?
Omega5002 Posted January 11, 2013 Report Posted January 11, 2013 Ok I was thinking the same thing but the website says the soundqube is stable to 2ohms does it handle 1ohm ok? That's when you strap them, alone it's 1 ohm stable, hence forth, why it's rated at 1200 rms at 1 ohm 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
KyLoGreen Posted January 11, 2013 Author Report Posted January 11, 2013 Ok I was thinking the same thing but the website says the soundqube is stable to 2ohms does it handle 1ohm ok? That's when you strap them, alone it's 1 ohm stable, hence forth, why it's rated at 1200 rms at 1 ohm ok thanks for you reply I'll just spend the extra money to get the soundqube
Kyle Morgan Posted February 13, 2014 Report Posted February 13, 2014 I actually went from the Brutus 1700 to the aq2200 and it was night and day. Amp couldn't handle the hdc12
TortoiseShore Posted February 13, 2014 Report Posted February 13, 2014 I actually went from the Brutus 1700 to the aq2200 and it was night and day. Amp couldn't handle the hdc12Amp couldn't handle the sub?..
oldsoundguy Posted February 13, 2014 Report Posted February 13, 2014 I ran that sub off a CT sounds 1400 @ .5 ohms and it took all the power easy. Give it 2000 RMS and it will be happy. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
