To eq or not? Need opinions
I have a Kdc x993 headunit and it has active capabilities and some nice settings for audio and I want to use a clarion eq, but if I do, I basically lose all the headunits capabilities.
Pros of eq:
Close volume and sub control
Could run Xbox through system off aux
Cons:
Lose settings from deck.
I'll be using a c1100.4 which also is active capable and a bc2000. I do have access to a cc1 to set crossover points as well.
So what would be better to use and fine tune my system? And why.
Thanks.
If it was me, I would spend the money on upgrading your head unit ... Possibly up to a DNX9980HD. Excellent EQ setup !!!
If I was going to add an EQ to your setup, I'd look for something like an Alexis 32 band to make it worth your wild ...
Just my suggestions here from someone that REALLY enjoys their music ...
Are you using your head unit for time alignment ??
I'm on my shitty phone ... Can you post the links to your head unit and the EQ so I can check the stats on them ???
Stay away from clarion eq.they are cheap.my buddy went through two in one year.just stick with your deck lwarn to use it.
My friend has had his for 2 years. The only features I really like about the eq is the aux input and how volume and sub level are right next to each other. Have another recommendation is I decided to use an eq?
  • Who's Online   1 Member, 0 Anonymous, 1397 Guests (See full list)
