Cox Posted January 12, 2013 Report Posted January 12, 2013 I have a d3700 and was wondering if anyone knew if this charger is ok with it. I couldn't find any specs on it as its older then I am. I have charged it with it before but I don't want to hurt the battery if this charger isn't meant to charge agm batteries Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Cox Posted January 12, 2013 Author Report Posted January 12, 2013 Any help? Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
DR.TINGTING!!! Posted January 12, 2013 Report Posted January 12, 2013 I've used a newer Schumacher charger on my d1200 and haven't had any issues. Iirc as long as the charger doesn't go above15v you're ok. The charger I use charges at 13.9v.
Cox Posted January 12, 2013 Author Report Posted January 12, 2013 I've used a newer Schumacher charger on my d1200 and haven't had any issues. Iirc as long as the charger doesn't go above15v you're ok. The charger I use charges at 13.9v. Thanks for the help Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
zack_e89 Posted January 12, 2013 Report Posted January 12, 2013 Idk about that one man.....it doesn't seem to have a trickle charge?? 97 Suburban 8 custom PSI Platform 3 18's
Cox Posted January 12, 2013 Author Report Posted January 12, 2013 Idk about that one man.....it doesn't seem to have a trickle charge?? I don't think it does but I keep a very close eye on it and I never try and "fully" charge it Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
Cox Posted January 12, 2013 Author Report Posted January 12, 2013 I try and take it off when it reads around 3 amps Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
DR.TINGTING!!! Posted January 12, 2013 Report Posted January 12, 2013 Do you have a Dmm or a voltmeter? I'd recommend monitoring/checking the voltage it charges at before just running it. Also make sure it doesn't over charge the batter as it is a "quick" charger not a trickle charger.
tacomaguy1 Posted January 12, 2013 Report Posted January 12, 2013 14.4 is the Max recommended by xs for chargers Team Flex Issues
Cox Posted January 12, 2013 Author Report Posted January 12, 2013 Well my dad has the dmm at his work shop right now but my stinger volt meter when I first turned to accessories on said 14.6 then dropped to 14.4 Kenwood Excelon x396AQ2200Fi Q 12XS D3400 XS XP30001/0 RADAFLEXStinger volt meter Mechman 240a alt
