Also as far as wiring goes, I know my amp puts out 1200 rms @ both 2 and 4 ohms. So with my two W3's which are single 4's I just wired them parallel to 2 ohms. Now with either set up, is it alright to wire to 1 ohm or will it be bad for my amp?
I mostly listen to rap and a bit of electro/dubstep with the occasional rock.
4 all day man! Depending what you tune to you'll have killer lows!
Car:
- 2013 Honda Accord Sport 6MT
- aFe SRI
Electrical:
- Big 3 w/ Execution Audio 0/1 AWG OFC
- Stock Battery
Audio:
- JBL Power Series 6.5 Comps up front (Running off HU power atm)
- JBL Power Series 2-Ways in the rear deck (Running off HU power atm)
Subwoofer:
- Sundown Audio X-15
- CT Sounds AT1400.1D (@1 ohm)
Bedroom:
- Yamaha RX-V365
- Pair of Klipsch KG4.2's
- 2 E8v3's in a 1.34ft^3 tuned to 30hz
- No Amp yet..
- CoolMax ZU900B PSU for amp
In my room & previous car:
- Amp: Soundstream TX1.1300D @ 4 ohms (520 watts)
- T-Line Enclosure tuned to 32hz
YouTube : http://www.youtube.c...r8?feature=mhee
What kind of amp, sir?
Car:
- aFe SRI
Electrical:
- Stock Battery
Audio:
Subwoofer:
Bedroom:
- Yamaha RX-V365
- No Amp yet..
Apline PDX M12. Says in the first post :P I'm guessing I can't if its only 2 and 4 ohm stable but I may as well ask and find out.
I knew that lol... And you can do 4 D2 E8 v3 and wire to 4ohms then if you get a bigger amp down the road you can wire to 1 ohm.. Or you can do 4 D4 and wire to 2 ohms or .5 ohms.. And yes I would check before trying that amp on 1 ohm just because it isn't listed there. Best bet is 4 D2 wired to 4 ohm!
Car:
- aFe SRI
Electrical:
- Stock Battery
Audio:
Subwoofer:
Bedroom:
- Yamaha RX-V365
- No Amp yet..
2 sa8's, dual 4 wired at 1ohm. more powerful than the e's, just a stronger sub. ive seen 2 sa8's take a ns-1. just two of em!
Edited by Hi-Po 5.0
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
Yeah I'm sure they can, on the meter? Still 4 v3s for the price of 2 why not just get 4 for fun and still have equivalent or more output. I'm sure if you built a solid box for 4 E8 v3s you'll deff have more output. Box is everything
Car:
- aFe SRI
Electrical:
- Stock Battery
Audio:
Subwoofer:
Bedroom:
- Yamaha RX-V365
- No Amp yet..
Just realized you said ns-1.. I was thinking of an ns (the sub). Yeah I mean clean power with correctly tuned amp, you can play with power all day depending on how much you beat on em
Car:
- aFe SRI
Electrical:
- Stock Battery
Audio:
Subwoofer:
Bedroom:
- Yamaha RX-V365
- No Amp yet..
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
