crispy_chick3n Posted January 16, 2013 Author Report Posted January 16, 2013 then instead of a 20 port switch, go to 5 port gigabit switches at each of the locations. 2 lines coming in means 2 modems. 1 router per modem for access to wireless devices. for a total of 2 routers. as many switches and wireless repeaters as required for proper wire length and placement. get rid of everything else. it will make your life MUCH better. seems to me that you strung a bunch of shit together and really had no idea what the proper options were. This page is crispy_chick3n approved. © crispy_chick3n inc
SoundFreakk Posted January 16, 2013 Report Posted January 16, 2013 Hmm that could be the problem 'cause out the top of my head a modem only gives one DHCP ip adress and the router creates multiple ip adresses from the ip adress given from the modem. Take a look at you're IP adresses at every router you're DHCP gives ip adresses in a certain range. Let's say you've this: First router 192.168.1.1 gives IP adresses from 1 to 150 you're second router can't give this adresses to that's going to conflict with eachother. so the second router should create IP adresses from 151 to 300 (151 just to be sure) Ascendant Audio/Rockford Fosgate Car Audio in House Build
crispy_chick3n Posted January 16, 2013 Author Report Posted January 16, 2013 Hmm that could be the problem 'cause out the top of my head a modem only gives one DHCP ip adress and the router creates multiple ip adresses from the ip adress given from the modem. Take a look at you're IP adresses at every router you're DHCP gives ip adresses in a certain range. Let's say you've this: First router 192.168.1.1 gives IP adresses from 1 to 150 you're second router can't give this adresses to that's going to conflict with eachother. so the second router should create IP adresses from 151 to 300 (151 just to be sure) i think i get what you are saying. you cant have 2 devices fighting for the same ip address This page is crispy_chick3n approved. © crispy_chick3n inc
SoundFreakk Posted January 16, 2013 Report Posted January 16, 2013 yep that's right. sorry maybe explained it a little bit complicated lol. But what sheena say's is what I would do. Only I would still use the other routers for more wifi coverage by connecting them to the router that's connected to the modem and shut down the DHCP server. so you're second router works as a access point. Ascendant Audio/Rockford Fosgate Car Audio in House Build
crispy_chick3n Posted January 16, 2013 Author Report Posted January 16, 2013 ill give that a shot and see where that gets me. hopefully it gets me one step closer to a more stable internet connection This page is crispy_chick3n approved. © crispy_chick3n inc
Sheena Posted January 16, 2013 Report Posted January 16, 2013 yep that's right. sorry maybe explained it a little bit complicated lol. But what sheena say's is what I would do. Only I would still use the other routers for more wifi coverage by connecting them to the router that's connected to the modem and shut down the DHCP server. so you're second router works as a access point. i suggested wireless repeaters instead of other routers. wireless repeaters if you dont know what they are.. they repeat the wireless signal.. wirelessly, you just need a power source and they are 3 step setup and then they boost the signal from the original router. so with that in mind.. i would: 2 lines coming to the house 2 modems 2 routers (1 per modem) as many switches and wireless repeaters as NEEDED. wireless function DISABLED on the modems (if they supply it, because the routers will take over from there) wireless function ENABLED on both routers wireless repeaters should be added IF NECESSARY. i know in my house wireless n 2.4GHz covers the entire house with max connection. (tested on ipad, and ipad mini) wired gigabit switches where necessary. this will simplify all connection issues. the routers will work as needed and you can set up the wireless repeaters to copy ALL wireless settings off of the routers, including SSID names, passwords, mac addresses, everything. it just boosts the signal. 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
Sheena Posted January 16, 2013 Report Posted January 16, 2013 if the internet is too slow, you will have to contact your ISP and upgrade your internet service. all aftermarket equipment that i listed that does all the traffic (routers and switches) will not limit how many devices you can connect UNLESS otherwise stated on the router/switch. obviously a switch with 5 ports can only accompany 5 ethernet cables. and most routers should accompany at least over 25 devices. (guesstimate) 09 Civic EX KDC-X395 (2) SKAR Audio VVX-12 Skar Audio SK-1500.1 4 cu ft @32 (new box and more port soon) Firing Forward not sealed off Stock 80 Amp Alt Big 3 In 1/0 Knu 2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu DD-1'd 13.8v drop
crispy_chick3n Posted January 16, 2013 Author Report Posted January 16, 2013 yep that's right. sorry maybe explained it a little bit complicated lol. But what sheena say's is what I would do. Only I would still use the other routers for more wifi coverage by connecting them to the router that's connected to the modem and shut down the DHCP server. so you're second router works as a access point. i suggested wireless repeaters instead of other routers. wireless repeaters if you dont know what they are.. they repeat the wireless signal.. wirelessly, you just need a power source and they are 3 step setup and then they boost the signal from the original router. so with that in mind.. i would: 2 lines coming to the house 2 modems 2 routers (1 per modem) as many switches and wireless repeaters as NEEDED. wireless function DISABLED on the modems (if they supply it, because the routers will take over from there) wireless function ENABLED on both routers wireless repeaters should be added IF NECESSARY. i know in my house wireless n 2.4GHz covers the entire house with max connection. (tested on ipad, and ipad mini) wired gigabit switches where necessary. this will simplify all connection issues. the routers will work as needed and you can set up the wireless repeaters to copy ALL wireless settings off of the routers, including SSID names, passwords, mac addresses, everything. it just boosts the signal. def an option, but not till i get paid again. at 80 a pop for a cheap cisco repeater, if i can make what i have work for me, at least for a little bit, ill be happy. the only reason i need all the routers is because this house is old as shit. limestone foundation, masonry work all around, and when it was updated last they used plaster for the walls. all materials that dont allow for signal to pass through good enough to be useable. This page is crispy_chick3n approved. © crispy_chick3n inc
crispy_chick3n Posted January 16, 2013 Author Report Posted January 16, 2013 if the internet is too slow, you will have to contact your ISP and upgrade your internet service. all aftermarket equipment that i listed that does all the traffic (routers and switches) will not limit how many devices you can connect UNLESS otherwise stated on the router/switch. obviously a switch with 5 ports can only accompany 5 ethernet cables. and most routers should accompany at least over 25 devices. (guesstimate) i cant remember exactly what speed i pay for, but i do know its one of the fatser connections that at&t offers This page is crispy_chick3n approved. © crispy_chick3n inc
SoundFreakk Posted January 16, 2013 Report Posted January 16, 2013 yep that's right. sorry maybe explained it a little bit complicated lol. But what sheena say's is what I would do. Only I would still use the other routers for more wifi coverage by connecting them to the router that's connected to the modem and shut down the DHCP server. so you're second router works as a access point. i suggested wireless repeaters instead of other routers. wireless repeaters if you dont know what they are.. they repeat the wireless signal.. wirelessly, you just need a power source and they are 3 step setup and then they boost the signal from the original router. so with that in mind.. i would: 2 lines coming to the house 2 modems 2 routers (1 per modem) as many switches and wireless repeaters as NEEDED. wireless function DISABLED on the modems (if they supply it, because the routers will take over from there) wireless function ENABLED on both routers wireless repeaters should be added IF NECESSARY. i know in my house wireless n 2.4GHz covers the entire house with max connection. (tested on ipad, and ipad mini) wired gigabit switches where necessary. this will simplify all connection issues. the routers will work as needed and you can set up the wireless repeaters to copy ALL wireless settings off of the routers, including SSID names, passwords, mac addresses, everything. it just boosts the signal. Off course I know what they are. But I was thinking about what he has. With your suggestion he has to go and buy more stuff but little bit easier to setup. With my suggestion he can keep the stuff he has now only little harder to setup. Ascendant Audio/Rockford Fosgate Car Audio in House Build
