I put hids on my 93 full size blazer and for some reason every so often but not every time as soon as i cut the lights on it kills my suv even going 80 down the interstate. any ideas?
Thats weird. How old is your battery? Is your alt running fine? Id test those.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
everythings fine the alt is 165 amp and the battery is only a few months old. ive noticed when they kill my truck, it has problems in overdrive. at low rpm itll miss and lash hard and down shift but when the lights dont do that i have no issues. and if it matters i lost my high beams before the hid install
You should have corrected your problems before you installed the HIDs ... Do you have a relay for each ballast ??
I see its a GMT400 ... Have you done any modifications to it like the 4-HI mod ?? or the 4-corner mod ??
I had to ground each relay at the head lights and not use any parts of the power factory wiring except the switched wires that go into the relays ...
