SixTwoRado Posted January 18, 2013 Report Posted January 18, 2013 I did this as well on my pioneer headunit. It's been good for a few years now. I did the same exact thing just as a precaution and following a suggestion from someone else that said it was a good idea on pioneer headunits for some reason. I also grounded the case to the frame nearby.
jeep0312 Posted January 18, 2013 Report Posted January 18, 2013 Im also having the same problem. looking to see how its resolved 2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/ Kenwood 352U HU (2) Incriminator Audio Death Row 12'' Soundstream Tarantula 1300W MTX 6.5'' mids & Infinity 4x6's in front doors Building as money comes in... beauty panels and amp rack 1996 Jeep Grand Cherokee Traded for a 2004 Malibu 2wd-4wd conversion 4in. lift 32'' Tires 2 Alpine 6.5 in front 2 Sony 6.5 craploads in rear Build: http://www.stevemead...__fromsearch__1 1999 Suzuki Sv650(Work in Progress)
jeep0312 Posted January 18, 2013 Report Posted January 18, 2013 Can an existing case screw be used? do the rca's need grounded it you ground the case too 2004 Malibu Classic http://www.stevemead...aq-25-jeep0312/ Kenwood 352U HU (2) Incriminator Audio Death Row 12'' Soundstream Tarantula 1300W MTX 6.5'' mids & Infinity 4x6's in front doors Building as money comes in... beauty panels and amp rack 1996 Jeep Grand Cherokee Traded for a 2004 Malibu 2wd-4wd conversion 4in. lift 32'' Tires 2 Alpine 6.5 in front 2 Sony 6.5 craploads in rear Build: http://www.stevemead...__fromsearch__1 1999 Suzuki Sv650(Work in Progress)
CoritaAlterado Posted January 18, 2013 Report Posted January 18, 2013 How about you try to ground your dist. block to a bolt in your trunk, like one of the bolts on the trunk hinge. Just make sure to sand it down to bare metal if you do. That might give you a better result.
85buickrivi Posted January 18, 2013 Author Report Posted January 18, 2013 How about you try to ground your dist. block to a bolt in your trunk, like one of the bolts on the trunk hinge. Just make sure to sand it down to bare metal if you do. That might give you a better result. so find a good spot in the trunk to ground the distribution block?? and eliminate the run of zero gauge to the main battery or add another ground from the distribution block to a good ground in the trunk??
85buickrivi Posted January 18, 2013 Author Report Posted January 18, 2013 I did this as well on my pioneer headunit. It's been good for a few years now. I did the same exact thing just as a precaution and following a suggestion from someone else that said it was a good idea on pioneer headunits for some reason. I also grounded the case to the frame nearby. u grounded the deck to the frame of the car or a spot in the body of the car??
CoritaAlterado Posted January 18, 2013 Report Posted January 18, 2013 Well before you take the 0 gauge out, i'd try different spots, just to see the results. Then after you're happy with the results you can take out the 0 gauge if you'd like. What kind of car is it?
CoritaAlterado Posted January 18, 2013 Report Posted January 18, 2013 I wasn't able to find good picture of the interior of that car, but you should try that idea about looking for different bolts and seeing which give the best result.
