Mobileaudio25 Posted January 18, 2013 Report Posted January 18, 2013 First off, what do you guys prefer? Circuit breakers vs fuses? And what size fuze/circuit breaker should I run between my under hood battery and the battery I the trunk? I'm running 0 ga wiring on a 180 amp alt. with 2500 rms
Tarball Posted January 18, 2013 Report Posted January 18, 2013 I prefer fuses. Fuse to the wire capacity. If ofc then 300amp should be fine. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
Raptorman Posted January 18, 2013 Report Posted January 18, 2013 Use a 300 amp ANL fuse. I hear circuit breakers get weaker every time they pop. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Polarbear Posted January 18, 2013 Report Posted January 18, 2013 i have 250 amp anl fuses and im running 3200 rms and it works fine! 02 impala VM-1 2 dc 12 xl's RF t2500bdcp Second skin damp pro Kenwood head unit 240 mechman alt d3400 in the front d3100 in the rear 50ft Rockford fosgate ofc 1/0
Mobileaudio25 Posted January 18, 2013 Author Report Posted January 18, 2013 Awesome, I appreciate it guys! Also do you ever have to charge a battery with an amg charger if you store it and it stays above 12.6v? Or if it's above 12.6 I can just throw it in the car and bump? I pulled the battery for the winter, the car is in storage
