Hi, I'm new to sundown audio but not so new to car audio
Essentially we do car upholstery , audio and electronics in the UK.
I built a budget system for a friend a couple years back - 2 12" pioneer subs 2.5 cuft sealed box- an 1800 Kenwood amp all that stuff.
Output and quality was there aswell as being pretty damn clean
But he's switching to a new car, an Astra sporthatch (google it )
And ideally wants the same kinda output but less space used up.
I decided on sundown after hearing a good things and reading good reviews-
Problem is I only have an 1800W max amp for the system.
So I need your help to chose either a SA 8 or an SA 10 both seem to give brilliant output for size.
So enclosure suggestions and oh I will definitely pull down the gains accordingly to suggestions
Thanks!
Oh btw only a SINGLE sub system
Welcome to SMD! You cant go wrong with Sundown.
With no clipping or distortion I've seen SA's take 1000 rms each
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
That's all settled then a 10" it is, thanks for that.
Also what sort of enclosure do you recommened for the sub and that power? 1.25 cuft tuned to say around 38 hz? The sub will be used for music and show off the output on music rather than pure SPL numbers
Thanks again
  • Who's Online   0 Members, 0 Anonymous, 1579 Guests (See full list)
