External Regulator Question
2 simple questions..
How much air do these need to stay cool?
And do they keep a constant voltage or does the voltage go down once the alt/regulator warms up?
Mine happens to be in the pcm of my car.
I have seen small metal box regulators that don't get hot but those were years ago.
All it does is regulate 12v, it doesn't let a lot of current flow through it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I have mechman EXTERNAL REGULATOR which is what most every other alt company uses a transpro 411 unit. Mine is rock solid whithout a load from idle and throughout normal driving rpm range. I set it cold start and it stays there even if it gets hot under the hood. I'm sure when it somes to some heavy basslines it will drop for a second but at the moment running just a sundown 100.4 when I raise it up a bit since I have the SMD VM-1 I notice on bass lines that the voltage actually hops up a volt for that split instance.
The mechman alt EXTERNAL REGULATOR SETUP came with a harness of its own completly bypassing stock alt harness so it doesn't have anything but the POT that I manually control if I want to adjust it. Most of the unit is mostly heatsink as well so it will do well under the hood but naturally since you need to use a relay to run it you can install it in the car just be sure to use preferably 8g for wire connections especially if running a bit of a distance, but 12g and see how it goes.
I'm referring to one of these guys
Me too. :ninja:
Me too. :ninja:
Sweet. Just making sure we are all on the same page
From what I've read you can run two alts off one regulator they both just have to be configured internally to work like this. good luck bro.
  • Who's Online   0 Members, 0 Anonymous, 2052 Guests (See full list)
