Ian Stith Posted January 27, 2013 Author Report Posted January 27, 2013 We ran a generator for an event last night. I believe it was a sine wave inverter. On a display it read about 13.9v which I presume was then bumped up to 240 (We run 240 here in Australia). It seemed to work great all night the thing was huge it was taller than me and probably like 2 meters long. Lukily though it didn't make that much noise it actually sounded like a large fan. The only issue though I think since it didn't have an earth plug everybody kept getting minor electrical shocks, which was fun to watch. I will definitly go for a grounding spike (what my fam. call earth plugs). I take it was probably one of those massive construction type trailor generators? I will also look into an older one of those... Im a broke student. still manage to have a pretty good system though.. (at least i think)
qu1cks1lver56 Posted January 28, 2013 Report Posted January 28, 2013 We rent these all the time But it's a bit big for your needs, I'm sure you could get by with a small honda generator just gotta watch the fuel. And definitely put in a ground rod. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
RCP Audio Posted January 28, 2013 Report Posted January 28, 2013 ^^^ that's like what we use. We have a couple we can just through on the bottom of the truck. Easy as PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
iceman1575 Posted January 31, 2013 Report Posted January 31, 2013 I've heard Honda EU's are about the best you can get, a bit pricey, but they work great. From what I understand you can also hook two together for additional output. If buying one outright isn't looking good, try renting one from a local construction company. POTATO!
ThreehundredC Posted February 1, 2013 Report Posted February 1, 2013 get a long extension cord and u can be way infront of the generator so the music is still good
Max1636 Posted February 3, 2013 Report Posted February 3, 2013 We ran a generator for an event last night. I believe it was a sine wave inverter. On a display it read about 13.9v which I presume was then bumped up to 240 (We run 240 here in Australia). It seemed to work great all night the thing was huge it was taller than me and probably like 2 meters long. Lukily though it didn't make that much noise it actually sounded like a large fan. The only issue though I think since it didn't have an earth plug everybody kept getting minor electrical shocks, which was fun to watch. Not that it really matters but actually the thing was more like 5 metres not 2 (Old Car) 1995 Volkswagon Golf MK3 2.0L: Fi SP4 18 On A DC Audio 3.5K In A PWK Box Hertz DSK 6" Speakers, Clarion HU 3x Fullriver 120aH AGM's, 225A Alt 2012 Subaru BRZ: Audison Prima APK 163 Bit One, Rockford Amps, Audison Sub
