Fully Custom Offroad Gearbox Build
So we're thinking about polishing this thing to make it pop on the flat black we're painting the car. Anyone have any advice or links on how to polish aluminum. The center rib may pose an issue as it was wire edm'd out and left a rough finish.
A polishing wheel on an electric grinder and some block-style compound
Hammerdown... 1%
As far as I know its going to take a lot of sanding and a lot of polishing
formerly known as Blue86f150
this sux camel dicks
Yeah i was thinking it would probably take a long time to get it looking good. Who knows we may just leave the machine marks in it or do a swirl finish on the side plates. I'm a little hesitant to do anything crazy on the center rib as that was about a grand worth of aluminum plus the hours of programming and machining. Also, its only .125" thick in some spots. The finish it has now would probably take paint well. We just started today mocking up the gearbox into the car. I'll add more pics tomorrow.
Here's the basics of polishing... you could probably leave the machine marks in if they're not horribly high.
Step 1:
Step 2:
Hammerdown... 1%
