Joe X Posted January 29, 2013 Report Posted January 29, 2013 So here is a suggestion based on the dims you give: Enclosure Specifications: Fb = 35 Hz Vb = 2.5 ft^3 External Height = 15.5 in External Width = 33 in External Depth = 16.5 in Port Width = 3 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 33 x 15 1/2 Left & Right Sides = 14 1/4 x 14 Top & Bottom = 33 x 14 1/4 L Port Internal Assembly Parts: Front to Back = 11 1/4 x 14 Extension = 13 x 14 Assembly guide (generic dimensions):
Fireitup Posted January 30, 2013 Author Report Posted January 30, 2013 Anyone have any input on this design or any other suggestions?
TRTC360 Posted January 30, 2013 Report Posted January 30, 2013 maybe TeamHT can chime in on this topic since he is the know it all genius when it comes to HDC3's or 4's, god forbid I recommend to tune higher with them, might get my head chewed off on this one '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
Fireitup Posted January 30, 2013 Author Report Posted January 30, 2013 Yeah i would love to hear from someone who has alot of experience with them. Wondering what i should tune it to with the power i will be giving it.. I want it to get low, but don't want to sacrifice my highs for it.
TRTC360 Posted January 30, 2013 Report Posted January 30, 2013 Yeah i would love to hear from someone who has alot of experience with them. Wondering what i should tune it to with the power i will be giving it.. I want it to get low, but don't want to sacrifice my highs for it. how low is low for you? some may consider 28hz low while others may consider 20hz low, like I said before and i'll say it again, tune to 36-38hz if you don't wanna sacrifice the subs high end output. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
Fireitup Posted January 30, 2013 Author Report Posted January 30, 2013 Yeah i would love to hear from someone who has alot of experience with them. Wondering what i should tune it to with the power i will be giving it.. I want it to get low, but don't want to sacrifice my highs for it. how low is low for you? some may consider 28hz low while others may consider 20hz low, like I said before and i'll say it again, tune to 36-38hz if you don't wanna sacrifice the subs high end output. So you think i would be good tuning it to 35 using Joe X's specs?
TRTC360 Posted January 30, 2013 Report Posted January 30, 2013 Yeah i would love to hear from someone who has alot of experience with them. Wondering what i should tune it to with the power i will be giving it.. I want it to get low, but don't want to sacrifice my highs for it. how low is low for you? some may consider 28hz low while others may consider 20hz low, like I said before and i'll say it again, tune to 36-38hz if you don't wanna sacrifice the subs high end output. So you think i would be good tuning it to 35 using Joe X's specs? specs look good to me, build it and find out '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
Fireitup Posted January 30, 2013 Author Report Posted January 30, 2013 Bump for any and all input. Otherwise will start building this after work. Thx in advance.
AMI CUSTOMS Posted January 30, 2013 Report Posted January 30, 2013 HDC3 wants 16-18 sq inches of port per cube regardless of power or design. That is min numbers, you can go with more port, but depends on power and coil selection. Alum coil will handle 3k + daily, I have proven it personally in several AQ HDC3 builds. As others have said no sealed on AQ woofers, suspension is way to stiff to warrent good output in a sealed enclosure unless the enclosure was massive. As reference like 4 cubes sealed for a 15. But will be as much as 3 db louder in same size box but ported with proper port area. Hope that helps. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
AMI CUSTOMS Posted January 30, 2013 Report Posted January 30, 2013 Also HDC3 like pretty high tuning for high SPL output. Lowest tuning I would recommend without killing the output is gonna be 35 hz. They start get nasty te closer you get to 40 hz tuning for good metering numbers. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
