Why does my amp do this?
One Way
Idk crazy, should be good at 2 ohm on each chan. I would put that amp in a friends car and see if it does that. Or put a different amp in your car to see if you still have the same problem. That way you can rule out HU, wires, and so on...
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Your deck goes up to 35 and you play it at 35?..... I'm thinking you got some distortion action which is just clipping away....
Maybe try setting your gains correctly and see what that does for you - maybe find a DD1 and see where your head unit distorts
I do have a dd1 lol that's how I tuned everything. And even so I lowered the amp gain a few clicks
Well, maybe set the amps with the DD1 while the head unit is at a more favorable volume - maybe 26 or so - just to see.
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
That was a double post - just throwing out no cost ideas....
Well I'm not trying to avoid the problem, I want to find out if anything could be wrong with my amp or if its something else.
The only thing I have done differently since I got new components was switching it to full range. Before that when I had my old speakers I had it only on high pass.
Can switching to full range from high pass effect the amp in any way. I mean I've had the high pass set for about two years and only switched it to full range when I got new speakers and the problem began.
I find it hard to believe that you have a deck that doesnt clip at 35/35 volume. I think you need to retune your stup starting with the deck and use -5db track. Follw the DD1 directions exactly. and see if the problem continues. Oh, and when you play dont increase your volume past where its set with DD1.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Why is it hard to believe? These keywoods show no distortion all the way up to 35. I did use the -5 track to set it up....but, I will retune it after I get home from school just to be safe.
  • Who's Online   0 Members, 0 Anonymous, 1419 Guests (See full list)
