Mobileaudio25 Posted January 31, 2013 Report Posted January 31, 2013 I'm running 3 agm batts, with the big 3 and an HO alt with all 0 gauge OFC... 2 questions... I have 2 in the trunk, do I need a fuse between them? And the second is do I ground them off of each other or make each battery it's own ground ?
ToNasty Posted January 31, 2013 Report Posted January 31, 2013 I would fuse the wire yes. Fuse to what the wire can handle ***Super Sellers List***http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers
Carbon Posted January 31, 2013 Report Posted January 31, 2013 YOu do not need a fuse between the 2 rear batteries. You want a fuse close to the battery in the engine comp. and one Near the 1st rear batt that the 1/0 run will be going to.
Crandis16 Posted January 31, 2013 Report Posted January 31, 2013 when in doubt, fuse it. But I wouldn't. ground them off eachother. you don't need to ground batteries to the frame in the trunk. Just wire them pos to pos to pos and neg to neg to neg My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
Miguels Posted January 31, 2013 Report Posted January 31, 2013 when in doubt, fuse it. But I wouldn't. ground them off eachother. you don't need to ground batteries to the frame in the trunk. Just wire them pos to pos to pos and neg to neg to neg you still need to ground them to the frame.. i would go pos to pos and neg to neg to frame my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Mobileaudio25 Posted January 31, 2013 Author Report Posted January 31, 2013 Ok, so there wouldn't be any benefit from grounding each battery out separate? And what size fuze should I run between my alt and first battery and Inbetween my first and second battery? The wire can pull 375 amps through a 20 ft run and my alt is 180 amps... I'm running 2500 w rms
Mobileaudio25 Posted January 31, 2013 Author Report Posted January 31, 2013 And I think he was saying to do 2 runs from pos/neg under hood to pos/neg in rear... I'm going to ground under the hood and ground the rears in the trunk. I don't want to do 2 separate pos/neg runs
Miguels Posted January 31, 2013 Report Posted January 31, 2013 no, you only need a pos run from front to back. ground the front to frame then ground the back to the frame.. now i get what his saying but its cheaper and better to ground to frame than to run a ground from the front to the back.. Damore have tested this and prove that grounding to frame is the way to go my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Crandis16 Posted January 31, 2013 Report Posted January 31, 2013 when in doubt, fuse it. But I wouldn't. ground them off eachother. you don't need to ground batteries to the frame in the trunk. Just wire them pos to pos to pos and neg to neg to neg you still need to ground them to the frame.. i would go pos to pos and neg to neg to frame what about if big 3 is ground to frame under the hood?Edit: just answered my question. looks like I did mine wrong :0 My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
Crandis16 Posted January 31, 2013 Report Posted January 31, 2013 when in doubt, fuse it. But I wouldn't. ground them off eachother. you don't need to ground batteries to the frame in the trunk. Just wire them pos to pos to pos and neg to neg to neg you still need to ground them to the frame.. i would go pos to pos and neg to neg to frame what about if big 3 is ground to frame under the hood? My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
