can someone double check this box for me pls?
vw passat
nope not enough port
hard for me to understand when a program tells you a range and you still ask if its ok the wrong way. althoguh the range is general your box isnt even near it
nope, you should be able to look at the program your using and see the issue at hand. if you cant at least help yourself first people shouldnt be holding your hand through it.
aero ports are based on 9-13 square inches per cubic foot.
so the 9-13 square inches were they need to come. in the port area or in the port area per foot?
tx guys for helping me
They refer to Port area per foot. With slot port boxes, 12-15 Port area per foot. Less port area, the more bandwidth you will have, and the lower you will be able to play below tuning. The more port area, the less bandwidth you will have, but in your "peak" area range, you will be louder than if you had less port area. A bigger box allows lower notes to be more defined, while at the same time, lowering power handling. It is the complete opposite for smaller boxes, a smaller box allows for more power handling but hinders low end. It is all a game of balance when building boxes, and building it to fit what you want to outcome from it. Hope that helps you man.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
thats not completely true at all.
  • Who's Online   0 Members, 0 Anonymous, 1645 Guests (See full list)
