possible to pull a minor hair trick?
Its a tiny car but im thinking about rearranging it and completely deleting the rear seats and putting the amps and batteries in the hatch area and the sub where the rear seats are supposed to be .. just depeds how it sounds to me off thr extra juice lol
DFAC
Beating Down The Block
2013 Kenworth T-660 Studio Sleeper-The daily and Money maker
I do what I want -push it till it pops!
sub up, port back...and 4000w of smoking woofer on video....PLEASE!
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Again see previous posts .. unless my port can be smothered against the hatch sub up port back isnt possible and I was also told to expect close to 4800ish from the 2200ds strapped at 1ohm :-) ...if I do get it recorded it will be with my note 2 so wont be excellent quality but ima try to record it
DFAC
Lol how many people run their 2200ds at .5ohm? Plus imp rise and such itll be fine if not ill just get some 3500.1s or bigger makes no difference to me
DFAC
Aren't the aqs 2 ohm stable strap? Not 1 ohm?
If that's true then we might not only see the sub go up in smoke but also the amps
the amps should be fine...but that woofer is gonna be toast....
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
We shall see .. part of me wants it to go up in smoke but part also hopes to prove you all wrong :-)
DFAC
You're probably more likely to do a hair trick with it reconed to 15 and given enough volume and port area, tuned low, rather than choked 18 in a box too small.
2007 Pacifica
Thats what im thinking aswell srp .. but thats the point of the extra power .. to make up for the smaller box ... it moved maybe 1/4 inch off my bd1000 .. now maybe 1/2 inch without clipping on 1 2200d .. sowe shall see what she does if I get a good check next week I might order my wiring and toolmaker goods but itll be next month before I get to order ther batteries
DFAC
Build over the rear seats. That's what I did in my 00 hatch
subwoofers - two eclipse 88120s
box - 3.4 cubes tuned to 32 hz
amps - aq1200 and pheonix gold zx450
New build :
2 obsidian audio 15s
same amp
6.1 cubic foot box tuned to 32 hz in a civic hatch
